Home > Maintenance & Modifications > Simple poll - bucket seats or standard?
What type of seats do you prefer?
Standard style
83%
 83%  [26]
Bucket style
16%
 16%  [5]
Total Votes: 31
edward
Trying to decide what I really want… bucket or standard style, any pros or cons from experience?
Ed.
Post #984794 8th Mar 2023 8:02am
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
i have never liked bucket seats for normal road cars as i find them difficult to get out of.
Post #984809 8th Mar 2023 11:00am
hank
Get whichever seats you like personally. > 110 XS Double Cab
Post #984810 8th Mar 2023 11:27am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I don't see the point of bucket seats in a Defender. Bucket seats are designed to hold you in place during high G corners, the Defender just does not do high G cornering. Bucket seats take up too much space and are generally less padded and not so comfortable on long journeys.
Post #984814 8th Mar 2023 12:00pm
geobloke
I have never found the standard seats in a Defender anything other than perfect for the job. I would say the TD5 era seats were more comfortable than the Puma era seats though.
If I was to change anything I might be tempted with the extended base.
Post #984824 8th Mar 2023 12:54pm
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi, my neighbour had leather bucket seats in his TD5 Alive 90 and they were dreadful in my opinion, they were very uncomfortable and as mentioned not that easy to get in and out of Thumbs Up cheers Paul
Post #984827 8th Mar 2023 1:00pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I've got Scheel seats, one of the best purchases I made.
Tip: But if you have an internal whoop from a roll cage, many seats (ie Recaro's) won't fit a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #984831 8th Mar 2023 1:20pm
edward
Which type do you have? And did they need special fixings? Thanks Ed
Post #984840 8th Mar 2023 2:28pm
Tdi4
I've got the Scheel Traveller LR Edition, with foldable seat base and the scheel foldable mount. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #984841 8th Mar 2023 2:34pm
edward
Thanks. Will
Check them
Out.
Post #984845 8th Mar 2023 3:16pm
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
I needed new seats when I "did up" the 110 for my Daughters wedding.
I got some buckets as they were a good price at the time.
Problem is they wear out quick on the side as you have to climb and slide over them.
The other problem as mentioned above they foul the internal roll cage.
Oh, and if they are tall you need to re-position seat belts or extend them.
I had to mess about to get them in.
Top end ones like recardo are good but I would choose one of the comfort seats from Exmoor next time.
Post #984910 9th Mar 2023 10:33am
geobloke
And do they fit with an internal roll cage hoop?
Post #984912 9th Mar 2023 10:55am
Tdi4
Yep they fit (just). You have to remove a knob (very easy, just slides on an of) to slide the seat past the post. But you only have to do that if you are (just like we) very tall and very short Laughing The knob is for adjusting the upright part of the seat, so we don't bother anymore to put the knob on.
Other advantage of the LR edition is the fact that the side of the chair are lower than the regular ones. So you don't have to climb "over" them. But still giving enough support. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #984925 9th Mar 2023 11:45am
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I assume you have never sat in a defender with genuine Recaros in there?
Post #984956 9th Mar 2023 4:43pm
Tdi4
Not in mine, because I've got an internal hoop so they don't fit. Very Happy
I sat in other cars in them. Also great seats, comes down to personal preference I suppose. I find them a bit racier so I prefer the Scheelmans. But if I hadn't had a fitting problem I probably would have chosen the Recaro's. I only started looking for alternatives when we concluded the Recaro's wouldn't fit. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #984957 9th Mar 2023 4:48pm
