Home > General & Technical (L663) > Base headlight adjustment? |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 |
I have the base spec Headlights that auto level, but they are too high in low beam. Does anybody know how to adjust these?
Cheers, Kyle 20MY Defender 110 Fuji White |
21st Feb 2023 3:14am |
It's been a while since I've adjusted Headlights before. Do I loosen that outer ring first I guess?
Click image to enlarge 20MY Defender 110 Fuji White |
21st Feb 2023 4:42pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2760 |
What makes you think they are too high. Are you getting flashed by oncoming drivers?
21st Feb 2023 7:21pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 163 |
HI,
In theory if your car has air suspension it should automatically adjust level, if you've never taken them apart they should be ok. these are the land rover instructions. Marco Click image to enlarge |
21st Feb 2023 7:33pm |
Thanks Marco, I tried to search that site, but I guess I used the wrong search wording.
To explain, I've been flashed frequently and I noticed the top of the pattern is well above the height of almost any vehicle in front of me. I have self leveling, but I believe the base line is too high. I'll try to change it and see what I get. BTW, I'm still working on ACC activation with IID. I haven't forgotten about that. Kyle 20MY Defender 110 Fuji White |
21st Feb 2023 8:34pm |
Thanks everybody. That did the trick. I'm no longer blinding other drivers.
22nd Feb 2023 4:27am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2644 |
Good to know. I had looked it up as I have the same. I’ve never been flashed but the lights sit uncomfortably high in my opinion so I will tweak them down a bit.
22nd Feb 2023 8:01am |
