![]() | Home > General & Technical (L663) > Base headlight adjustment? |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 ![]() ![]() ![]() |
I have the base spec Headlights that auto level, but they are too high in low beam. Does anybody know how to adjust these?
Cheers, Kyle 20MY Defender 110 Fuji White |
It's been a while since I've adjusted Headlights before. Do I loosen that outer ring first I guess?
![]() Click image to enlarge 20MY Defender 110 Fuji White |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2944 ![]() ![]() |
What makes you think they are too high. Are you getting flashed by oncoming drivers?
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 172 ![]() ![]() |
HI,
In theory if your car has air suspension it should automatically adjust level, if you've never taken them apart they should be ok. these are the land rover instructions. Marco ![]() Click image to enlarge |
Thanks Marco, I tried to search that site, but I guess I used the wrong search wording.
To explain, I've been flashed frequently and I noticed the top of the pattern is well above the height of almost any vehicle in front of me. I have self leveling, but I believe the base line is too high. I'll try to change it and see what I get. BTW, I'm still working on ACC activation with IID. I haven't forgotten about that. Kyle 20MY Defender 110 Fuji White |
Thanks everybody. That did the trick. I'm no longer blinding other drivers.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
Good to know. I had looked it up as I have the same. I’ve never been flashed but the lights sit uncomfortably high in my opinion so I will tweak them down a bit.
