Home > General & Technical (L663) > Base headlight adjustment?
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
I have the base spec Headlights that auto level, but they are too high in low beam. Does anybody know how to adjust these?
Cheers,
Kyle 20MY Defender 110 Fuji White
Post #983175 21st Feb 2023 3:14am
Retroanaconda
There are two adjusters on the top of the headlight unit under the bonnet, kind of knurled knobs with a hex key slot in them. Apparently they are the height adjusters.
Post #983184 21st Feb 2023 8:23am
forzahog
It's been a while since I've adjusted Headlights before. Do I loosen that outer ring first I guess?
Post #983232 21st Feb 2023 4:42pm
lightning
What makes you think they are too high. Are you getting flashed by oncoming drivers?
Post #983252 21st Feb 2023 7:21pm
mmbanf
Italy
HI,
In theory if your car has air suspension it should automatically adjust level, if you've never taken them apart they should be ok.
these are the land rover instructions.
Marco
Post #983255 21st Feb 2023 7:33pm
forzahog
Thanks Marco, I tried to search that site, but I guess I used the wrong search wording.
To explain, I've been flashed frequently and I noticed the top of the pattern is well above the height of almost any vehicle in front of me. I have self leveling, but I believe the base line is too high. I'll try to change it and see what I get.
BTW, I'm still working on ACC activation with IID. I haven't forgotten about that.
Post #983267 21st Feb 2023 8:34pm
forzahog
Thanks everybody. That did the trick. I'm no longer blinding other drivers.
Cheers,
Post #983281 22nd Feb 2023 4:27am
Retroanaconda
Good to know. I had looked it up as I have the same. I’ve never been flashed but the lights sit uncomfortably high in my opinion so I will tweak them down a bit.
Post #983286 22nd Feb 2023 8:01am
