Home > General & Technical (L663) > Who's changed their oil |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 |
https://bundf-schmierstoffe.de/Castrol-EDG...ium-FST/en No Mud flaps for my 90.!
----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
4th Feb 2023 11:40pm |
MaartenB89 Member Since: 10 Dec 2022 Location: Antwerp Posts: 5 |
Seems like I got ripped off the most by JLR Antwerp (Metropool) here in Belgium. They called me two times to ask whether I "really wanted the oil and filter changed already" and then ended up charging me EUR 520 for it.
I checked with a smaller workshop first but they said they couldn't do it as they did not have the tool for it(???). They used to work on my Jaguar XF but they said they can't work on the new Defender. |
13th Feb 2023 8:20am |
DavidITGuru Member Since: 15 Aug 2011 Location: London Posts: 99 |
Sounds like they've done a full service at that price and not just an oil change. From the videos I've seen on YouTube there are no special tools but I will defer to those with more technical expertise on that front.
13th Feb 2023 8:46pm |
Completed the oil change today having closely followed Umberto's excellent video. So pleased I did it at 13 months / 6,009 miles. I was surprised at how black the oil was.
Click image to enlarge Click image to enlarge Click image to enlarge |
14th Feb 2023 10:35pm |
IRBails Member Since: 25 Feb 2021 Location: Wollongong, NSW Posts: 25 |
Can the oil be changed by extraction like on the Range Rovers? I purchased an electric pump, 12v , which connects over the oil dip stick tube. Run the pump and oil goes straight to waste container. Simpler and cheaper than the vacuum extraction pumps.
15th Feb 2023 2:16am |
Yes, that's how I did it, by extraction albeit hand pumped rather than electrically. Here's the video I followed:
15th Feb 2023 5:34am |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1422 |
I've done 8000 miles since the end of October so I'm also thinking about doing my first oils change.
Looks pretty straightforward. |
16th Feb 2023 10:23am |
DaveCNB Member Since: 15 Mar 2022 Location: So. Cal Posts: 63 |
I just went and paid for the dealership to do a change, I had a coupon so it wasn't too much more than buying the required (massive : ) amount of the recommended oil and the vacuum pump setup.
I figured that not having to deal with the old oil and cleaning up the spill I would have transferring the old oil to a new container to recycle/dispose of properly and not having to clean up the pump was worth a few bucks : ) I know that per LR's service recommendations that this wasn't strictly necessary but I sure do sleep better at night now! Oil is cheap, an engine is not : ) |
4th Mar 2023 9:20pm |
chrispuk Member Since: 22 Nov 2021 Location: Wirral Posts: 13 |
D250 at 6000 miles. Went to my local independent Land Rover specialist. Full spec oil service, filter, and entered on LR electronic service History £155. Plan to do this every 6000 miles as do lots of short journeys and want to look after the engine and avoid problems due to oil dilution from failed DPF regenerations.
25th Mar 2023 2:37pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2898 |
Engine oil in a diesel will go black very quickly, sometimes almost immediately. lt doesn't mean the oil has had it, just means it's doing its job.
Nevertheless l would never leave the oil change for 20,000 miles. l plan to change it every 10,000 with the first oil change at around 6,000 The lngenium 3.0 diesel doesn't suffer from oil dilution due to failed DPF regenerations. |
25th Mar 2023 4:43pm |
Spec ??, vague , with a brand new car.. And Reset.. There is absolutely no reason to reset at this mileage. Have you seen and checked the oil they used ? Suppose not the original Castrol Landrover Titanium, bla,bla. ( Over £100,- /£120,- minimum wholesale) Incase something will happen with your engine you would void your warranty. Don't reset in between ( early oil changes/ refresh) wait on the car to display. Just my 2 cts/penny. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
25th Mar 2023 5:46pm |
That’s good news as it was a problem in my last BMW kept exceeding sump oil level Max. Absolute pain especially as no proper dip stick in X1 BMWs.
25th Mar 2023 6:40pm |
That's good advice not to reset the service indicator.
The fact that you did your own oil change could theoretically void your warranty. lf you are still worried about it, get the oil changed by a reputable indy and keep the receipt |
25th Mar 2023 7:50pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2671 |
If you use the correct spec oil and filter etc. then it cannot affect your warranty. Besides you’d not actually tell them and they’d never be able to find out, so long as you leave the computers alone.
26th Mar 2023 8:41am |
