Home > Puma (Tdci) > What are the predrilled holes in the chassis for? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3431 |
The large ones are alignment holes when fitting the bulkhead. But unsure if both on each side are used, but presumably yes, as 2 holes on one side give both location and rotation. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
13th Feb 2023 5:13pm |
PS, you have a bigger hole just behind the bulkhead outrigger.
I think holes are good to have as aid in drying any water that gets in. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
13th Feb 2023 5:15pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 754 |
The hexagonal holes are for rivnuts...
13th Feb 2023 5:31pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2661 |
Rivnuts for side steps or various other accessories that may or may not be fitted along the line. Some of them are for transmission mounts which were bolted onto the chassis on earlier vehicles.
13th Feb 2023 5:39pm |
trevorg Member Since: 28 May 2022 Location: Aisne Posts: 51 |
Thank you. A useful bit more knowledge though still a long way to go before I fully understand it all.
13th Feb 2023 6:51pm |
WPRO18 Member Since: 13 Feb 2023 Location: London Posts: 89 |
I always thought Land Rover did it to help retain mud and dirt... well at least it for my prior Landy
13th Feb 2023 8:40pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
They are there to let the air inside the chassis to make it lighter for lifting when it needs replacing... 1982 88" 2.25 diesel
14th Feb 2023 7:42pm |
