Home > My Defender > Fuji 110 LS3 build
Page 49 of 61 <123 ... 484950 ... 596061>
mcma1
Can anyone confirm that Narvick black is non metallic?? The adventure grille and surrounds come Santorini which I have on the roof but trying to decide if I should match everything Santorini or repaint all Narvick? I only have the rear door and arches to paint Santorini… Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #980600 31st Jan 2023 7:27am
kenzle8a
I'm not sure but even though im the least OCD person out the gloss black grills / roof / arches and the matt black bonnet miss match makes my teeth itch.
Post #980602 31st Jan 2023 8:08am
mcma1
Did some digging so the Trophy one had the headlight surround intake from the Works V8 and also the wing top as it was a prototype used for the press release. The Trophy 1 and 2 builds only have the wing top. I cant get this from LR so made up a design pretty close from some pictures and will print it over the next day or so.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #980923 2nd Feb 2023 8:34am
Co1
Yes, it is non metallic. Thumbs Up
Post #981003 2nd Feb 2023 6:10pm
mcma1
Thanks Col,
26hr print in ASA with no disaster is like winning the lottery, Just need to finish and then paint. Will need to track down some original wing top & side covers if anyone has some? and will paint them all together to match.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #981166 3rd Feb 2023 9:14pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Result with the printing Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #981170 3rd Feb 2023 9:23pm
JOW240725
I'm still amazed by 3D printing, looks awesome.
Is it just for show or will it become the air intake? James
Instagram @suffolk_rovers
Post #981179 3rd Feb 2023 10:40pm
mcma1
Not sure to be honest. If I could figure out a way to cut out the grille in the headlight surround I could keep my current one and just stick this on the wing for show. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #981180 3rd Feb 2023 11:03pm
Co1
Bit of a chew, but could you print the entire headlight surround with the vent holes in it? Failiting that, cnc a steel template, clamp it on each side, drill out the centre of each hole then push a square broach of the appropriate size through each?
Post #981201 4th Feb 2023 8:36am
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
that looks great what a good result.....
Post #981205 4th Feb 2023 9:40am
DSC-off
Printed intake looks great!
For a one-off, laser cutting would probably be the most cost effective. No tooling required.
A trial with a few holes in an old headlight surround would show the finish result.
Post #981214 4th Feb 2023 10:39am
mcma1
Had thought about water jetting but turns out the works surround is actually just a round slot cut out and then mesh fixed from behind so not a new design tool. That’s easy enough to do. Made an offer on eBay this morning for some old surrounds to play about with. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #981227 4th Feb 2023 12:39pm
mcma1
Friend kindly ran this last night for me, very pleased. After all the messy work is complete I will blast and anodise black, then skim the boundary face.
I will print a surround to screw from underneath to secure the new leather gaitor.
And slowly making progress on the graphics, have a 90 pickup scaling the rear arch Laughing
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #981709 7th Feb 2023 8:22pm
mcma1
Spent a lot of time prepping this, took it as far as 2000 wet grit so ready for a coat of Satin paint to match the standard wing and side covers.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #982352 13th Feb 2023 8:35pm
Likeomg
Whistle
Post #983550 24th Feb 2023 2:56pm
