Home > My Defender > Fuji 110 LS3 build |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2904 |
Can anyone confirm that Narvick black is non metallic?? The adventure grille and surrounds come Santorini which I have on the roof but trying to decide if I should match everything Santorini or repaint all Narvick? I only have the rear door and arches to paint Santorini… Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
31st Jan 2023 7:27am |
Did some digging so the Trophy one had the headlight surround intake from the Works V8 and also the wing top as it was a prototype used for the press release. The Trophy 1 and 2 builds only have the wing top. I cant get this from LR so made up a design pretty close from some pictures and will print it over the next day or so.
Click image to enlarge Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
2nd Feb 2023 8:34am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
Yes, it is non metallic. |
2nd Feb 2023 6:10pm |
Thanks Col,
26hr print in ASA with no disaster is like winning the lottery, Just need to finish and then paint. Will need to track down some original wing top & side covers if anyone has some? and will paint them all together to match. Click image to enlarge Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
3rd Feb 2023 9:14pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 825 |
Result with the printing Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
3rd Feb 2023 9:23pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
I'm still amazed by 3D printing, looks awesome.
Is it just for show or will it become the air intake? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
3rd Feb 2023 10:40pm |
Not sure to be honest. If I could figure out a way to cut out the grille in the headlight surround I could keep my current one and just stick this on the wing for show. Andy
3rd Feb 2023 11:03pm |
Bit of a chew, but could you print the entire headlight surround with the vent holes in it? Failiting that, cnc a steel template, clamp it on each side, drill out the centre of each hole then push a square broach of the appropriate size through each?
4th Feb 2023 8:36am |
mrfirepro Member Since: 06 Nov 2020 Location: kent Posts: 232 |
that looks great what a good result.....
4th Feb 2023 9:40am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1433 |
Printed intake looks great!
For a one-off, laser cutting would probably be the most cost effective. No tooling required. A trial with a few holes in an old headlight surround would show the finish result. |
4th Feb 2023 10:39am |
Had thought about water jetting but turns out the works surround is actually just a round slot cut out and then mesh fixed from behind so not a new design tool. That’s easy enough to do. Made an offer on eBay this morning for some old surrounds to play about with. Andy
4th Feb 2023 12:39pm |
Friend kindly ran this last night for me, very pleased. After all the messy work is complete I will blast and anodise black, then skim the boundary face.
Click image to enlarge Click image to enlarge I will print a surround to screw from underneath to secure the new leather gaitor. Click image to enlarge And slowly making progress on the graphics, have a 90 pickup scaling the rear arch Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
7th Feb 2023 8:22pm |
Spent a lot of time prepping this, took it as far as 2000 wet grit so ready for a coat of Satin paint to match the standard wing and side covers.
13th Feb 2023 8:35pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2651 |
Click image to enlarge |
24th Feb 2023 2:56pm |
