Home > My Defender > Fuji 110 LS3 build
Page 50 of 61 <123 ... 495051 ... 596061>
mcma1
Need some help please. No one appears to do a black SS bolt kit for the exterior. Any suggestions of a company I could use to spec what I need? Could my existing SS bolts be coated? On the Trophy all the doors have black bolts but I may just do the rear and cross member few under the rear door as it’s all getting painted black. Cheers Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #985871 17th Mar 2023 5:30am
Co1
Have you looked at getting a standard set Xylan coated? Turns them black and gives corrosion protection.
Post #985872 17th Mar 2023 6:02am
rustandoil
Post #985873 17th Mar 2023 6:09am
mcma1
Post #985875 17th Mar 2023 6:53am
kenzle8a
Accu will stock most things in black stainless or they will make them to order.
https://www.accu.co.uk/5-precision-screws
Post #985887 17th Mar 2023 8:10am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I had a set from nakagennagga (the guys in Germany) they were on back order so I added my name to the list, they have some issues, but I am told its due to the process of how they are coated, some have the middle of the screw still silver etc, but they worked for what I needed, though not cheep. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #985904 17th Mar 2023 9:46am
mcma1
Making progress, mainly taking bits off Big Cry . Croytec hope they can anodise the handles black which would be handy and just trying to arrange the roll cage delivery.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #986706 24th Mar 2023 7:59pm
Just had a catch up, looking great and excellent attention to detail.
Takes a vast amount of time as well. Thumbs Up No Guts, No Glory.
Post #986709 24th Mar 2023 8:16pm
mcma1
SPRING20 discount code on JLR Classic parts has helped. Thumbs Up Andy
2014 Corris 110 SW
LS3 V8 build...
Post #986840 26th Mar 2023 9:06am
mcma1
Test fit of the winch, 4 bumper holes are a little off which is annoying but easy enough the fix.
Managed to get the handles apart for black anodising ( small M3 bolt with loctite was the potential issue )
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #987811 3rd Apr 2023 6:04pm
mcma1
Bought the closest registration I could to the original on the Works Camel Trophy....
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #988206 7th Apr 2023 10:19am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Andy,
Have you looked at Performance Coatings in Cork for your bolts
Shane
Post #988261 8th Apr 2023 12:12pm
mcma1
Thanks Shane,
Sills have proved tricky to get as obviously Bowler wont sell them so I bought a set standard from them, fitted the mounting brackets and a quick scan will let me create the T2 design. They are a single piece cut and folded with 2 end caps, and I can then retain the jacking points.
I will also print a bracket to hold the battery conditioner that clips onto the new sill under the door.
And then wrapped the top of the shocks as the visible yellow was annoying me Big Cry
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #988983 14th Apr 2023 5:37pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Out of curiosity, why have you gone bilstein instead of Fox 2.0's? I could be wrong but you had the Fox set up a little while back? Would ike to know your thoughts. 4.0 V8 Defender 90
My Instagram
Post #989021 14th Apr 2023 9:05pm
kenzle8a
There’s always the black bilsteins if you fancy an upgrade.
https://www.4x4proyect.com/parts/bilstein-...ock-kit/en
Post #989026 14th Apr 2023 10:33pm
