Home > Td5 > Bottom Door Seal for Sill post 2005 fit on 2003 model year? |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1041 |
Hi All,
I am refurbishing the doors on my 2003 110 and came across these bottom seals on LRParts marked as post 2005. They are obviously different and look much better than the twisted lip style seals on my car. So question is do these fit? The go up the side as well, how does that work with the standard door seals? I am obviously not too worried about having to drill a hole.. https://www.lrparts.net/catalog/product/vi...tyle-seal/ Finally, I know from experience that aftermarket (Britpart etc) seals tend to be too hard and only the original LR seals work well, does this apply to these bottom seals as well? Thanks |
29th Jan 2023 7:02pm |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
I have this mod on my to do list. Needs a little effort but fitting the Puma seals will have the best end result.
http://defender90xs.blogspot.com/2014/08/u...s.html?m=1 TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
29th Jan 2023 7:47pm |
jimmyvonk Member Since: 31 Aug 2017 Location: Melton Constable, Norfolk Posts: 34 |
Thanks for the link - about to have a go at this this week so a great help!
29th Jan 2023 10:28pm |
Let us know how it goes and if you notice the difference with the new seals... TD5 hardtop to Puma inspired Poptop - my build thread
30th Jan 2023 8:01am |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 485 |
They fit ok on earlier doors also without cutting anything off (that completley defeates the object of them) Best to make a jig for hole drilling though from thin aluminium or plastic
30th Jan 2023 10:38am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 931 |
These will fit the early welded doors quite well. Just move the plastic clips to new holes on the rubber seal and line them up with the remaining holes on the bottom of the door when you drill out the OE bottom seal. Only two need to be moved. Quite easy really. After that only two holes need to drilled in your door frame, to secure the side plastic tab.
Do it, well worth the effort. Good luck Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
30th Jan 2023 1:50pm |
So, went out and did mine today on a 2004 Defender TD5.
I just ripped off the old rubber seals, and pulled out / drilled out the old rivets and marked up and drilled the new side holes. All the original holes were fine, just needed new ones for the end bits. Made sure all holes were 5mm, painted the holes and any bare metal and went to the next door. When all doors done, went back to the start and now the paint was dry, fitted the seals. Huge improvement, less sunlight in the footwell! And all done and dusted in about 2 hours. All went far to well for a Landy job. Last edited by jimmyvonk on 4th Feb 2023 2:31pm. Edited 1 time in total |
2nd Feb 2023 12:56pm |
Thanks for sharing the update - looks great!
Interesting that all the bottom holes lined up - my truck is the same age as yours, but my doors were replaced about 5 years ago so I may or may not be as lucky as you.. TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
3rd Feb 2023 8:48am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
But your doors are already the later style pressed ones which these seals are designed for. They must have been retrofitted onto your 02. Steve 02' 110 TD5 Double Cab Rebuild Thread |
3rd Feb 2023 9:23am |
The flap seals look to have been on from new, and as I had to drill extra holes for the ends must have been like that from the factory. Maybe 02ish was a changover period. The joys of Defenders is playing guess the spec. Went out for a run today and much less drafty and I 'think' less road noise. |
3rd Feb 2023 12:24pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2640 |
The newer seals didn’t come in until 2012 or something like that, they had the simple rubber flap ones up to then, so your retrofitted doors were from a 2005-2012 vehicle.
A 2002 would definitely have had the old welded doors from the factory, with the exception of the rear tailgate which was updated from 2002 model year. |
3rd Feb 2023 12:52pm |
I wonder what colour they are inside the doors?
3rd Feb 2023 1:25pm |
I've just ordred 2 genuine weatherstrip seals to do my truck
Any recommendations on how best to rustproof the new holes I'll have to drill? TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
3rd Feb 2023 1:57pm |
Hmm, you made me check now... registered 12/04, chassis number is 5A 69**** I made a mistake and blame night shifts.. Sorry. |
4th Feb 2023 2:30pm |
