Home > Td5 > CPS woes |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 220 |
You can rule out the starter motor interference by tow/bump starting it. 1990 Defender 110 200TDI Camper - now converted to Td5 power
30th Jan 2023 9:12am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 628 |
Once I have repaired engine ECU with broken resistor in CPS signal circuit - it was working, but was extremly sensitive to "the right" voltage from CPS. After repair, it was working with nearly anything.
So just to be sure - try another engine ECU. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
30th Jan 2023 9:17am |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 |
sadly because of where its parked i have to start it to get somewhere where i can tow start it A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
30th Jan 2023 9:28am |
Not sure if im at that point in the testing .. but I'll keep it in mind A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
30th Jan 2023 9:30am |
And problem fixed ..!
Thre good news is that along the way I've fixed a whole batch of things and done some preventating maintenance in the end the bad starting problems were down to noise from the starter motor. Replaced that and starts on 1st turn of key ... more than once ... yay!! Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
1st Feb 2023 9:31am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1090 |
Good. I was going to say, when you mentioned 'nothing', the CPS does not control the starter, it controls the firing (diesel). All resolved and you have some spare sensors for your collection.
1st Feb 2023 10:43am |
Yeah!
probably a few more than id like to have ... but certainly happy bunny A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
1st Feb 2023 11:49am |
