Home > Technical > Steering wheel drifting anti-clockwise.
Page 2 of 3 <123>
PCM
Sorry Gents. Been away for a bit. Took your advice and glad I did.
Turns out it was a loose bolt. Unwinding every mile. Had the car in for tracking a few months back at ATS and they did such a poor job they didn’t torque the bolts back up.
Could have been spectacularly bad. Embarassed
Changed a drop arm at the same time and now have straight steering with no play…
Post #979065 21st Jan 2023 7:36am
Do you know which bolt?
Thanks for reporting the finding to us, glad it had a good ending. It could have been much worse if you hadn't thought to ask.
Post #979106 21st Jan 2023 11:52am
geobloke
Blimey... Which bolt/nut was it? What have ATS said about it? Really pleased the worst did not happen...
Post #979107 21st Jan 2023 12:01pm
roel
I think the nut that keeps the drop arm on the steering house. I had that before. I just had a little play as the locking plate wasn't bend tight enough. But in my case it was play while driving not just to one side. The drop arm could move up and down a bit. Roel
2003 90 Td5 (2009-now)
Post #979125 21st Jan 2023 2:39pm
ATS would not have messed with the drop arm during an alignment check, or at least should not. Drag link lock bolts, perhaps?
Post #979151 21st Jan 2023 6:14pm
nitram17
How many miles has your truck done pcm?I am also very interested in which loose nut caused your particular symptoms?
Post #979153 21st Jan 2023 6:20pm
PCM
It was the bolts holding the track arm on. They were working loose causing the steering wheel to rotate.
I added a few shiny bits a few month back and had it 4wheel aligned afterwards.
Wish I hadn’t.
ATS are having none of it. Say it would have happened anywhere.
Just glad I didn’t rotate the steering wheel on rhe splines.
Post #979156 21st Jan 2023 7:12pm
nitram17
Shiny ...Sumo Bars?...... so just the track rod ends then .everything else was ok?which branch of ats did you use as im in your area and i would like to avoid them if possible!
Post #979158 21st Jan 2023 7:53pm
PCM
Although I suspect it was ATS I’m not going to specifically blame them as it “could” have happened afterwards.
I did however visit the branch in team valley. Very Happy
Post #979172 21st Jan 2023 10:42pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Wish I hadn’t.
I strongly suspect they failed to tighten the drag link clamp bolts/locknuts after doing the tracking.
This is why I do all my own car repairs, you can't trust anybody because it is often impossible to tell the difference between idiots and experts until it's too late!
And as an additional point, you can't 4wheel align a Defender so that's a con! It's just the tracking and then steering wheel position, nothing is adjustable at the back axle.
Tracking is stupidly simple to DIY on your driveway with a couple of metal rods and some mole grips or similar to clamp them together. No actual measurements or numbers required.
I should really make a YouTube vid of it, would make me famous Rolling with laughter
Post #979173 21st Jan 2023 11:06pm
LR90XS2011
agree 100% with the previous post DEFENDER 90 TDCI XS,
Post #979178 22nd Jan 2023 6:28am
PCM
Seriously make that video.. it may not make you famous but will make lots of people (like myself) a lot more knowledgable. I was useless until I bought a defender and it’s slowly making me into a mechanic. With the help of this forum.
I’ve done servicing, brakes, electrical work and would have done tracking if I’d have found that video. 😇
Post #979182 22nd Jan 2023 7:52am
rustandoil
I'm not understanding this... Did the drag link unscrew?
Post #979185 22nd Jan 2023 8:26am
I think it must have been shortening itself (unless the vehicle is LHD, which I doubt).
Post #979188 22nd Jan 2023 8:36am
Dinnu
On early LandRovers, the nut on that clamp was of the Aerotight design (not a nyloc) so they took heat and oil contamination consideration in the design. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #979191 22nd Jan 2023 8:49am
Page 2 of 3 <123>
