![]() | Home > Technical > Windscreen washer nozzle replacement |
That's a good idea Blackwolf. Fancy sharing how you modified the wiring?
I can sympathise about the stiff wiper blades. In other countries there are specialised winter wiper blades with softer rubber and/or double blades per wiper... But as we are British changing tyres in autumn is too much so wipers is a long long shot... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17618 ![]() ![]() ![]() |
Easy, remove the wiper "relay" (which is actually a timer unit not a relay) and remove or bend flat the blade for receptacle 6 on the connector. This is the feed from the washer switch into the "relay" which triggers the wipe function. Since wash and wipe are on the same stalk it is very easy to squirt as long as you wish then click the wipers on. |
Excellent....
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
Right - my brain is hurting with this one. 1. New column stalk fitted. 2. New pump sourced. 3. Fitted - nothing happening. Been across everything with a volt meter - 12v showing at the connector that plugs into pump but it does not run. 4. Rigged up a way to run pump from a spare battery - runs fine. 5. Pulled the Optimal relay - nothing at the pump connector, plug it back in - 12v but pump does not run. 6. When the engine is running - 14v showing at the connector but pump does not run. What am I missing here? Rgds. Chris |
Is the polarity correct in the pump connector? and have you checked the Earth is good?
Polarity is ok - worked fine for over 12 months.
I did suspect it might be an earth issue - there is an earth lead on the Optimal supplied loom supplement. I will have a look (when it stops raining.....). Rgds. Chris |
If I recall the earth wire is quite short on that loom so I expect you have fitted it to the bodywork some place. As I have done. It is worth dismantling it, cleaning it up and refitting with some contact grease (vaseline would do) to prevent it corroding as quickly again. If it is that mind...
That is the next move methinks. Rgds.
Chris |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
No I did not. Is that a relatively easy thing to do on the Td5? Presumably its located somewhere down near the pumps? 2005 Td5 90 XS 1989 V8 110 CSW |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Mine is located under the bonnet on the near side close to where the wing meets the bulkhead (next to the heater plenum). You will see the pipework heading toward the bulkhead. It’s simply a ‘pull off push on’ and they are very cheap. As Blackwolf suggests (and perhaps I should have) you can completely remove it.
I only mentioned it as I was thinking I’d have to commit to a new nozzle/pump etc. but thought I’d just change it to see if it made any difference as they get clogged up and the diaphragm distorts. It really did shock me just how much of a difference it made - which in reality demonstrated just how ineffective the old one was. It is now better than when I bought the Landy. Worth a try… |
![]() Click image to enlarge Other types and other vendors are available… |
I shall locate it and remove it then, thanks Screbble! Fingers crossed that will resolve the lack of squirty pressure. 2005 Td5 90 XS
1989 V8 110 CSW |
