Home > Puma (Tdci) > Overheating in 6th gear going uphill (SOLVED) |
MartinJC Member Since: 12 Jul 2014 Location: Gauteng Posts: 13 |
You are definitely dealing with a leak between compression & Water, could be Head-gasket, cracked head or cracket cylinder wall! 2002 130 td5 Gameviewer
2004 110 td5 SUV 2012 110 2.2 HCPU 2013 110 2.2 PU Gameviewer 2014 110 2.2 SUV 2018 110 Traxxas RC |
10th Jan 2021 3:01pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3497 |
Great thread and all useful stuff.
On the up side, you have a lot of new kit fitted to your Defender Glad you have it resolved |
23rd Jul 2021 7:43pm |
Yesjus Member Since: 19 Sep 2022 Location: Surrey Posts: 78 |
Hi, still trying to find the Issue with my defender having power loss issues!! How did you finally determine it was head gasket? |
22nd Oct 2022 10:50pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
well done finding the issue
these types of faults can be so frustrating DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
23rd Oct 2022 5:30am |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 |
@yesjus I pretty much replaced everything it could have been!
Off the top of my head that was: New radiator New thermostat New CHT sensor New VCV New water pump New fuel rail New air filter New coolant caps! MAF & MAP were less that 12 months old New coolant I cleaned everything with contact spray. I made sure the EGR was properly blanked off and removed. I also replaced something at the back of the engine although can’t remember what this was now. I did a number of RELD tests at different times (cold start, warmed up, half warm etc) and they were all negative. Being able to see the temp in real-time helped. I had a nanocom wired up and when I saw the temp rising I could react to it. When this first started I would find myself in the outside lane on the motorway and suddenly I’d have no throttle and the speed would just start dropping. Wasn’t the best feeling! It would feel like you’ve just driven into a massive headwind! The temp gauge would be in the red but would start dropping after a few seconds. When it got back to middle the power would come back on and it was back to normal. This only really happened in 6th gear accelerating up hill! It was possible to catch it if I saw the temp rising. I would slow and drop down to 5th and then the gauge would drop down. Trying to diagnose this was super frustrating!! I did take the car to a couple of garages (landrover indies) and both mentioned head gasket. I’ve now done about 4000 miles since the HG was done and it’s all back to normal. I do now run an ultragauge so that I can see speed,rpm,turbo psi,fuel rail and temp! Good luck with sorting your car! I didn’t want to do the HG first as no one was really sure it was that. Having read most of the internet looking for solutions I pretty much exhausted the list of what it could be. On the plus side it’s like I have an almost new engine now and I know this car intimately now! 🤣 |
23rd Oct 2022 7:34am |
Thanks for this @greyman110
Really helpful info 👍 Working my way through the new parts at the moment!! Currently I’ve changed the VCV with no change however I’ve just done the CHT sensor and fingers crossed it hasn’t done it since so hoping it’s that!! |
31st Oct 2022 10:19pm |
defenderfraggle Member Since: 06 Dec 2022 Location: Leiden Posts: 14 |
Thanks for this super useful story. My tdci is going to the garage on Thursday. Running hot when driving motorway in 6th gear, and within seconds after idling I can drive again. Off motorway no issues. Whenever revs are up it cools quickly. Almost everything is done. I'm fearing the gasket. Seems like there a vacuum whenever I open the expansion. engine heat up quickly when slowing down (letting go of gas, nu keep gear)
We'll see. Thanks! |
10th Jan 2023 4:25pm |
Car came back from the shop and is fixed. Head gasket. Nothing to be found in cooling fluid.
I’m happy. |
7th Mar 2023 11:08pm |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
Hi Greyman110
Recently I had a similar issue with 6th Gear 120km/h and the car pushing coolant out of the header tank. Believed it to be blown head gasket but on removal can not really see any obvious place where the gasket was leaking. When your gasket was leaking did you notice any issue / mark on the gasket when it was removed to show where it was leaking? Thanks Nick 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
10th Mar 2023 2:45pm |
Hi Nick, yeah, that was visible on the inside. And even though there was a leakage there were no exhausts to be found in the fluid. What did happen though is theat fluid was ‘leaking’ away. Into the cilinder apparently, nothing to found in the oil. It was a leakage to the front of the engine.
Regards, Jan |
10th Mar 2023 4:00pm |
