Home > Puma (Tdci) > Overheating in 6th gear going uphill (SOLVED)
Page 1 of 5 12345>
Greyman110
So this has been going on for a while and after spending £££ and looking at different things without success, I kind of just left it hoping it would go away if I didn’t use it for a while...but naturally it didn’t! Laughing
So now I’m really trying to fix it!
PROBLEM
When in 6th gear, especially accelerating going up hill, the temp gauge suddenly rises quickly all the way into red and the fuel then cuts out for 10 seconds while the temp goes back down. Then the fuel kicks back in and it keeps on going. Around town driving is fine.
I’m also losing some coolant but this is only from the cap.
This started out of nowhere. Just one day I felt like I had run into a strong headwind but after a few seconds it was fine. Then it happened more frequently and I noticed the temp gauge going up. Now it happens every time your accelerate hard in 6th.
WHAT I KNOW
Generally the running temp stays within the normal working parameters- until I accelerate in 6th gear. It doesn’t happen in any other gear. There are no fault codes. I’m not sure if it my imagination, but when I change into 6th it feels a little sluggish.
WHAT I’VE DONE SO FAR
- VCV Replaced (last 12 months)
- New MAF & MAP (last 12 months)
- New oil cooler (2 months ago)
- Cleaned MAF & MAP (today)
- Added 2 shots of Millers to full tank of super. (Yesterday)
- New air filter (k&n) (last 12 months)
- Chem-tested the coolant tank to see if there’s gas escaping and its clean.
- Replaced the coolant cap (I’m on 3rd one this year. Now have the Ivenco one)
I’ve also spent what seems to be hundreds of hours looking at the entire internet to try and work out what this problem is. I now know I’m not the only person who has it but I just can’t find a fix!
WHAT I WANT TO DO
- Check the turbo thing! I saw a video about how the arm should move freely so I’m going to look at that tomorrow. If anyone can tell me how to take those very small clasp things off, that would be handy Very Happy
CONSIDERATIONS
- Maybe replace the air filter to paper. I read that the oil for k&n can be an issue.
- Change the thermostat to one that opens at a lower temp.
If I’m honest I’m not super handy around cars but I do have a tool set and every kind of spray and grease available so as long as something isn’t too complicated, I’ll give it a go! I don’t really want to keep taking it to the garage for it to not be fixed which has happened a couple of times now.
If anyone has an useful tips or ideas what this could be then please let me know! Bow down Bow down Bow down
Post #865400 4th Nov 2020 5:34pm
Have you tried replacing the cylinder head temperature sensor?
Post #865415 4th Nov 2020 6:49pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
As above - the CHT sensor will protect the engine from overheating by cutting the fuel supply momentarily giving the impression of a fuel problem and throwing no fault codes. Just because you're offended doesn't mean you're right.
Post #865423 4th Nov 2020 7:33pm
Greyman110
I came across that today in a post somewhere.
I'll do that one and see. I thought I saw someone say you needed a special tool to remove it?
I did clean it off today as it had a film of oil on it - If its the one that sits at the back of the engine bay by the injectors that is Very Happy
Post #865430 4th Nov 2020 7:45pm
shropshiredefender
From the Workshop manual.
"Cylinder Head Temperature (CHT) Sensor
The CHT sensor is located at the centre rear of the cylinder head (transmission end). The sensor measures the
temperature of the cylinder head and not the temperature of the coolant."
Thumbs Up Just because you're offended doesn't mean you're right.
Post #865442 4th Nov 2020 8:46pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Replaced a few thermostats for sticking shut, causing it to overheat
Easy to test too
Post #865444 4th Nov 2020 8:50pm
jst
Does it need a special tool? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #865445 4th Nov 2020 8:51pm
bear100
No special tool, but what I did was cut a slot in the socket which made it so much easier
On mine the temp needle would rise slightly when cold 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #865449 4th Nov 2020 9:00pm
Preston110
United Kingdom 2007 Defender 110 Td5 CSW Bonatti Grey
Exact same thing was happening to my defender 110. Was the coolant, crack somewhere in the system and it was leaking away and causing it to do the same thing.
Post #865451 4th Nov 2020 9:04pm
Greyman110
Easy to test too
How would you test to see if its working properly?
Post #865452 4th Nov 2020 9:08pm
Greyman110
I can't find any leaks in the system by looking but im not losing coolant unless I hit the 116 degree mark.
With the old coolant caps I could often hear them hissing after a run.
Post #865453 4th Nov 2020 9:14pm
Greyman110
Looking over the engine this morning, the radiator looks like it was replaced when the inter cooler was fitted by the previous owner.
When I unscrewed the coolant cap, the system is still pressurised from when I drove it yesterday. Is that a potential issue?
Post #865517 5th Nov 2020 10:24am
captain slow
United Kingdom 2014 Defender 110 Puma 2.2 CSW Corris Grey
Have you checked your EGR valves? 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten)
300 Tdi 110 CSW (gone but not forgotten)
Post #865518 5th Nov 2020 10:33am
Greyman110
Egr was blanked off and removed when it went to have the maf and map done. It’s always been off but I had it done properly.
Post #865522 5th Nov 2020 10:58am
Greyman110
Could this be the issue....
After driving the car and getting up to temp I felt the radiator. It’s hot to warm across the top and cold everywhere else.
What do we think?
Post #865529 5th Nov 2020 11:32am
Page 1 of 5 12345>
