Home > General & Technical (L663) > Who's changed their oil
Page 1 of 7 1234567>
lightning
....before the recommended 2 years/20,000 mile interval?
l questioned the dealer and they said it "wasn't necessary" but there's no way l'm leaving it for 20,000 miles on such a high tech engine.
l'll do an interim oil change at 10,000
What do others think?
Post #976536 3rd Jan 2023 12:46pm
tooslo964
Wales
I intend to do the same next month , just coming up for 10k by then
Post #976539 3rd Jan 2023 1:00pm
MattF
United States
There's no way I go as long as recommended by LR regarding oil service. I'll do my first at 5K then every 7500 after that. Cheap insurance at a minimum. There's a long discussion with varying opinions on the landrover.com site.
Post #976546 3rd Jan 2023 1:23pm
Tim in Scotland
I had mine changed by the dealer at 11000 miles/ 12 months in June 2021. They argued like mad that it wasn’t necessary so I told them
A) I know the awful failure rate of Ingenium engines due to oil dilution
B ) if I want an oil change done more often than recommended I’ll get it done and I’m offering you the job rather than going to an indie LR specialist at half the price and still using JLR parts and oil…….
C) Will I do damage to the engine changing the oil early?
They booked the car in and did the job in the end and I nearly fell over when the bill was presented - £120 was way less than I had been quoted initially………… turned out LR was doing cut price oil/ filter changes and Adblu refills - basically the cost of the labor and VAT were zero and it was returned washed and cleaned inside too! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #976547 3rd Jan 2023 1:28pm
markb110
And that is the con of buying the five year service package upfront when JLR (UK) knows full well that the average client will return the vehicle at the end of year three. Hence only one service in Year two.
It’s cash flow that is re-invested, looks good at the shareholders meetings.
Post #976557 3rd Jan 2023 2:19pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I had mine done at 12months at main dealer £199 inc. They were insistent it wasn't required but I insisted, When it was done the service manager came over and agreed it was a wise move Rolling Eyes
Post #976577 3rd Jan 2023 4:55pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
If you don’t intend to keep the vehicle outside it’s warranty period then why waste money on interim oil service?.. stick to JLR recommendations.
If the vehicle is “ a Keeper” then it might be worth it to you.
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #976584 3rd Jan 2023 6:10pm
Moo
Ukraine
I’ve done 6000 miles and am thinking of doing mine in the next week or so. I’m old school and just don’t believe oil will last as long as they say.
Post #976587 3rd Jan 2023 6:49pm
lightning
As above l guess.
Why spend more than necessary when the vehicle will never be out of warranty in your ownership.
However this may in part explain the issues with older vehicles and things like turbo failure, main bearing issues etc
For instance
A three year old Defender is returned at the end of lease....the first oil change was done at 21,000 and then it's put through the auctions by the main dealer.
Bought by a used car dealer it has a second oil change at 37,000 using cheap bulk oil and an aftermarket filter.
The second owner doesn't change the oil for a further 18,000 miles because the "car dealer did it before delivery"
At five years it gets a third oil change, at a local "do it all" garage and then after seven years (and another 15,000) the turbo fails. That's changed but then it fails the MOT because it's burning oil and the DPF is knackered.
At that point the vehicle's future is at risk. Quoted £2,000 for a new DPF the owner has it bypassed which gets the Defender running but throws a warning on the dash.
At the next MOT it's deemed to need an engine, which has the owner screaming all over the forums that their "low mileage Defender is rubbish" and that Land Rover "clearly didn't design the engine properly" and they will be seeking compensation through the courts
Post #976588 3rd Jan 2023 6:53pm
Clemmo
Problem is… many of us remember an era of mineral oils and engines you had to “ bed in”
Reality is…things have moved on.
Synthetic Oils simply do not degrade like a mineral oil.
Engines are built to much tighter tolerances than years ago.
Gone are the days of a sump full of metal particles
All manufacturers have moved forward with their technology
We have to move with them if we own a modern vehicle.
Having been involved with engine manufacture and load testing engines for 1000s of miles I am happy to follow manufacturers recommendations.
Post #976591 3rd Jan 2023 7:04pm
Retroanaconda
I change mine myself halfway in between the official 21k services.
Oil is cheap. Engines are expensive.
Post #976603 3rd Jan 2023 8:45pm
Defendit..
Netherlands
Wait at least till 10.000 miles. Really no problem.
Buy the original oil, see picture, new formula for summer and winter
 No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #976605 3rd Jan 2023 8:58pm
Moo
Ukraine
Thanks. I probably will. It won't be long before I hit 10,000.
Post #976614 3rd Jan 2023 10:24pm
zilch
Australia
on our P400 we change the oil at 12,000 KM's on average,
6 months and 12,500 kms interim oil and filters changed (oil and air filters)
12 months annual service completed at 22,0000 KM.s
24 months annual service completed at 35,000 KM's (left it longer than 6 months we had planned
as the Landie had hardly moved)
seems more sensible interval than the LR one based upon Australia's climate and driving conditions yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #976618 4th Jan 2023 5:24am
lightning
Yes l think there's no harm done from changing the oil and filter every 10,000 miles
I realise oil, and engines have moved on. It will also depend of course on the type of use the vehicle gets.
Post #976623 4th Jan 2023 8:16am
