![]() | Home > Puma (Tdci) > Transfer box selector gone sloppy |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
There are value-engineered plastic connectors in the linkage and it is possible that one has come unclipped. There are also bits which can break. If you have a look from underneath ideally with someone else waggling the lever you can probably see what's gone wrong. From your description it is unlikely to be inside the transfer box.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3479 ![]() ![]() ![]() |
Someone else on this forum is also looking for that link. Seems to be a common failure (mine was replaced by previous owner).
https://www.defender2.net/forum/topic85961.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I've just seen the price of the replacement part from LR (and it's not available aftermarket as far as I can tell), around £220 for a piece of plastic tat!
Coops Member Since: 20 Jan 2022 Location: Cambridgeshire Posts: 16 ![]() ![]() |
Thanks blackwolf and dinnu…took a look underneath and it was the control rod thing. The plastic connector had popped off and was hanging down. A bit tight to reach but popped back on (photo)…yet to road rest but hopefully ok
