![]() | Home > General & Technical (L663) > New LR Defender heated washer jets |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2926 ![]() ![]() |
The wires must be inside the feed pipes then?
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
Im interested as it would be interesting to see if you can retrofit Mike
MattF Member Since: 28 Oct 2022 Location: Norwalk CT Posts: 32 ![]() ![]() |
Would a parts diagram help?
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
On the parts diagram they list different wiper arms either with heated jets or without
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
r18wly Member Since: 07 Jul 2021 Location: Lancaster Posts: 6 ![]() ![]() |
Thanks for that explanation ![]() |
Nashvegas Member Since: 25 Dec 2021 Location: Portland, Oregon Posts: 40 ![]() ![]() |
This is so odd. I can't really grasp how the washer jets are heated on my 2020 X model with heated washer jets on the build sheet / window sticker. No evidence of heating on mine anywhere. ie -- no electrical plugs going to the wiper arms whatsoever, just the rubber tubing. If it's indeed inside the tubers, how would it get "out" of the washer tube? And it would need a plug on the vehicle harness. All of which I didn't see on my car. Just driving thru the mountains last weekend, my screen wash froze up and stopped working in a snowstorm, I wasn't thrilled. I had blue -20 degrees fluid in and it wasn't nearly that cold... So interested in detective work here. |
