![]() | Home > Puma (Tdci) > Cold start issues |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 916 ![]() ![]() ![]() |
We have had unusually cold weather this month. Are the glow plugs still the original ones? 2008 2.4 110 Utility Station Wagon XS.
Dean Watson Member Since: 17 Jul 2011 Location: Derby Posts: 262 ![]() ![]() ![]() |
Yes original and i have also heard they are used for DPF burnoff as well to ignite the injected diesel so may cause more wear i suppose
Any other 2.2 owners can let me know how long glowplug light is supposed to be on for? Last edited by Dean Watson on 16th Dec 2022 9:16am. Edited 1 time in total |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 617 ![]() ![]() ![]() |
Interesting, my 2014 2.2 has been the same during this cold weather. Mine does have the original glow plugs...
One thing I have noticed is that the problems were worst when I filled up the tank with diesel from a shell filling station. I normally use the local Tesco, which is what I have now and it started with little issue this morning, despite the fact it's probably the coldest it's been so far this winter.
Trundlebus Member Since: 15 Jul 2014 Location: Herts Posts: 99 ![]() ![]() |
I know you say the battery is fully charged but it could still be the cause. Batteries hate cold weather. Try using some jump leads from another battery and see how it reacts. My Saab 2.2 diesel showed exactly the same problem, in cold weather, battery showing full and it really struggled. New battery and all was back to normal.
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1862 ![]() ![]() ![]() |
I've had the same issue the last couple of mornings, but I know I've got at least one glowplug that has come up as not working on a fault code before, so I've always just put it down to that.
I have recently replaced the battery so I've ruled that out from my issue 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20702 ![]() ![]() |
Mines been the same, I’m not too worried really cold weather. The longer they are parked up the more likely too as battery voltage drops back more TheThunderRolls🇬🇧🇺🇸
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2230 ![]() ![]() |
If you use an odb2 code reader you should see diagnostic trouble codes for the glow plugs if they are faulty. I.e P0380 / P0670. You can also check resistance of glow plug, IIRC it will be circa 0.7 Ohm if ok.
However it’s more likely to be an ageing / low battery. My 2.2 has glow plug light on for circa 3 seconds when it’s very cold. Re warming up, remember diesels do take longer than petrol, and in the cold I bet you have the heater on hot at full blast, sucking heat from the engine plus your engine Is surrounded by cold air. Also you are probably driving slower and at lower revs due to slippery roads. So a combination of those things results in 5 plus mins to get to temp, which seems reasonable given the circumstances. |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Not quite sure on Land Rover but as a previous Ford Diesel Tech the glow plugs continued to be powered for quite some time once the glow plug light goes out to assist in cold running. Many makes do this Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Don’t forget aging starter motors as well is a factor and possible loose battery clamps and main grounding point. TheThunderRolls🇬🇧🇺🇸
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
What new battery did you replace it with Rosco? I need one also being 5 years old and slow to start. Keith |
A battery, if not left to drain to very low on lots of occasions should not need replacing after just 5 years.
However if you have a Puma you won’t get better than a Varta LED95 ( Leisure, EFB (enhanced flooded battery) Dual purpose 95 amp hour) 850 CCA battery. It’s the upgraded version of the original LR fitted battery. |
Iain.
May well be glow plugs then. I haven’t had any checks done as yet. 120000 miles. 2012 |
ob1conobe Member Since: 10 Jan 2014 Location: Gloucestershire Posts: 52 ![]() ![]() ![]() |
Regarding the issue of not getting up to temp, this thread should be of use:
https://www.defender2.net/forum/topic71379.html |
