Home > Puma (Tdci) > Cold start issues
Page 2 of 3 <123>
ob1conobe
United Kingdom 2014 Defender 90 Puma 2.2 HT Alpine White
Regarding the issue of not getting up to temp, this thread should be of use:
https://www.defender2.net/forum/topic71379.html
Post #974971 17th Dec 2022 2:07pm
hornet
I think the thread starter should indeed take a closer look at the temperature sensor (CHT), the short glowtime suggests an incorrect temperature reading.
It certainly doesn't belong here but is not completely off topic, but I have made a few attempts with a new viscous fan. I have also installed a temperature sensor in the oil pan, the thermostat is working properly. I have no catalyst and no EGR.
These are my long-term observations:
1. fuel consumption drops by approx. 5% when driving without the viscous fan. I noted 10% drop in consumption when I removed my failed viscous fan. I think you really only need the viscous fan at very warm temperatures and higher load, I read 90°C oiltemperature at 35°C outside temperature and load. So nothing to worry about.
2. the viscous fan ensures that the oil temperature never reaches 80°C when driving overland, but actually hovers around 60°C (outside temperatures around freezing point). It is never standing still and therefore cooling the hole time. Electric driven thing would be much better.
3. with the viscous fan removed and the same outside temperatures, the warm-up phase improves and you now reach more than 70°C
4. only strenuous motorway journeys cause the oil temperature to rise to 80°.
The setting of the heater plays a major role; you have to heat moderately so as not to draw too much energy from the cooling water and thus also cool down the oil.
Conclusion: In winter and in the transitional period, I drive without a viscous fan. At temperatures around freezing point, the only way to achieve reasonable oil temperatures is to cover the radiator.
Notes:
Leaving the engine running (cold start) for the purpose of de-icing causes very high wear of the engine and ensures oil dilution through fuel intake, which in turn affects the oil viscosity and results in wear. The 2.2l machines are particularly at risk here. I recommend doing a used oil analysis every time you change the oil.
There are auxiliary heaters for these cases and they work fine.
I run RAVENOL NDT Nord Duty Truck SAE 5W-40 oil which makes the engine run more quietly and has actually made it more rev-happy. I have a very mild tuning from BAS
Post #975433 22nd Dec 2022 8:45am
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Ok
so an update on this , further cold weather today and further issues starting , turns over well but took a long time to catch and sounded lumpy
No issues when hot
new battery
no stored fault codes
different diesel gauge fill up
ran a tail of injector cleaner through it as well
its fairly slow to come to temp would be the only other issues with
only done 32k
I have 2.4 100 as well , this starts fine no issues , glow plugs stay on for at least 6/7 sec on the 2.4 barely 2/3 sec s on the 2.2
I am thinking some kind of temp sensor not pulling in the glow plugs for long enough
any more ideas or what to check?
Post #978530 17th Jan 2023 3:10pm
Dean Watson
another update
there is no cht sensor on 2.2 just coolant temp sensor checked this on cold start and temp was 2 degc so about right,
no fault codes
no blown fuses
glow light stays on for 3 sec max
turn key again and it briefly flashes then goes off
still poor starting
help!
Post #979331 23rd Jan 2023 11:39am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
 Roaming around 🇳🇴🇨🇭
Post #979334 23rd Jan 2023 12:12pm
Dean Watson
is that right, where is it then ? has anyone got a colour pic?
on 2.4 its down back of the engine connector is on top in line with oil filler
nothing there on mine uk spec 2015 ht?
Post #979338 23rd Jan 2023 12:19pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
keith wrote:
Rosco wrote:
I've had the same issue the last couple of mornings, but I know I've got at least one glowplug that has come up as not working on a fault code before, so I've always just put it down to that.
I have recently replaced the battery so I've ruled that out from my issue
What new battery did you replace it with Rosco?
I need one also being 5 years old and slow to start.
Keith
Keith apologies I've only just spotted this.
I've fitted an Yuasa HSB020 from Halfords. They had an old price on the shelf which was cheaper than the 019, which thankfully they honoured, less a 10% discount as an AA member (a scheme which I think they've now dropped) plus a further 8% through a voucher scheme via my employer. So all in all I got a bit of a steal I think lol.
Dropped straight in without any issues. Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #979341 23rd Jan 2023 12:33pm
Rosco
Dean, does this help?
Lorryman100 wrote:
The CHT sensor is mounted at the coolant manifold junction at the top rear of the cylinder head. The sensor is made up of a probe with a length of cable to the harness plug which is mounted on top of the cylinder head beside the red engine lift bracket under the plastic engine cover.
No 13 in the below diagram.
If you have a DMM you can back probe the harness plug, and with the engine warm at operating temp take either a voltage or Kohms reading. The input to the sensor is a 5V reference voltage supplied from the voltage divider circuit within the ECM. The earth from the sensor is also connected to the ECM which measures the returned current and calculates a resistance figure for the sensor which relates to the cylinder head temperature. So at normal operating temp of 88-90 degrees Celsius you will get a resistance value of 2.9 Kohms or 0.64 volts. The higher the readings the colder the temp and the lower the reading the hotter it is. So -40 �Celsius will give you 925 Kohms and 4.45 volts, where as 150 �Celsius gives you 0.563 Kohms and 0.14 give or take a %. Thumbs Up
Brian.
Taken from here https://www.defender2.net/forum/post144576.html 2007 - Stornoway Grey 90 XS SW - Gone
Post #979342 23rd Jan 2023 12:48pm
Dean Watson
hi
thats on a 2.4 , on a 2.2 its not there , and i cannot figure out where the earlier black and white drawing is in the engine bay
i have the sensor and the socket but cannot find where it is on the 2.2?
Post #979347 23rd Jan 2023 1:01pm
Most of the Ford forums etc seem to suggest that the CHT is in roughly the same place on both the 2.4 and 2.2 engines, which in the light of your comments is strange.
Perhaps you don't have one, and that is why you have an issue!
Post #979351 23rd Jan 2023 1:29pm
Dean Watson
bizarre
will nip out and take a pic , no connector there at all felt doen back and cannot feel another cable gong anywhere
its been fine since new with cold start until just before Christmas so i would assume its got one as i have no dtc codes
last fews months really difficult , its not the type of this to drop off is it!
will post a pic of mine
Post #979355 23rd Jan 2023 1:39pm
Rosco
Having scoured the diagrams on lrworkshop.com, I'd say there isnt one.
Clearly listed on the 2.4, item 11
https://www.lrworkshop.com/diagrams/land-r...head_44989
Nothing for the 2.2
https://www.lrworkshop.com/diagrams/land-r...ad_2.2tdci
Even went through the electrical components list they have and it was the same result. Odd there isnt one. 2007 - Stornoway Grey 90 XS SW - Gone
Post #979360 23rd Jan 2023 2:20pm
Dean Watson
hi that where I am at the moment
2.2 defender doesn't have one
2.4 does
so as far as I can see glow plugs must use coolant temp sensor in hose as trigger for glow plug
any more ideas what is holding the glow plugs to only 2/3 secs use?
Struggling now!
Post #979366 23rd Jan 2023 2:49pm
I'm pretty sure that 2-3 seconds is quite normal for a 2.2. That's certainly what mine seems to do and it starts without issue. Darren
Post #979368 23rd Jan 2023 2:52pm
Dean Watson
ok thanks so that's the timing sorted if its normal
I have no fault codes regarding the glow plugs, as they are hard to get to I haven't tested or removed them
no blow fuses
its a 35k mid car but used for relatively short trips ,(wife's a nurse) could they be sooted up?, I have put a double dose of injector cleaner through it, to no noticeable difference
I have bought a set go glow plugs as next step if no there ideas, they haven't really had that much use however?
its been fine up to this year, never had an issue till this winter
new battery as well and 100% charged
any more collective knowledge
Post #979371 23rd Jan 2023 2:59pm
Page 2 of 3 <123>
