Home > General & Technical (L663) > Commercial Variant |
Beefbeefbeef Member Since: 01 Sep 2022 Location: Newport, Shropshire Posts: 7 |
You'll notice a massive improvement even with springs on the new Defender compared to the old one! I can't speak for air suspension on the new Defender as mine has springs (2021 Hard Top) (although I did test drive a 90 on air) but I've had it on several other 4x4s (Landcruiser, F-Pace, Grand Cherokee) and I can honestly say I don't think it makes much difference plus is notorious for breaking albeit the warranty will cover that. There are certain things I look for (and happy to pay extra for) in a vehicle but air suspension is somewhere down the list. |
1st Sep 2022 5:28am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2885 |
The 110 will probably be smoother than the 90 anyway whether it's on coil or air suspension because of the longer wheelbase.
My 90 on coil springs is great on road, although off road it's really no better comfort wise than my old 2005 Defender 110. |
1st Dec 2022 6:05pm |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 |
Do you really think so? I can tear around fields like I’m on tarmac in mine. Haven’t twa**ed my head on the door once yet https://instagram.com/bentheoandrews
2nd Dec 2022 1:33am |
Well l've not tried that! lt it probably better on fields and maybe l should have gone a bit faster to smooth it out
2nd Dec 2022 8:51am |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Venture in Bolton are doing it. Just waiting for mine to get booked in. |
3rd Dec 2022 10:44am |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 |
Does anyone know what parts need to be changed for the conversion and the part numbers?
From my knowledge: Rear part of the floor Rear windows trim (the silicone will stay in place unless the doors are repainted) Rear door wiring in order to enable the windows? Rear door switches Rear door "handles" for closing the door B pillar grab handles in order to close the holes left by the bulkhead Rear seats and seat bases and seatbelts Anything else? |
7th Dec 2022 9:25am |
Little PSA for any hard top owners or potential owners....
Not being a London dweller, was down visiting my little bro last week. Was driving from Battersea to Bow and the sat nav took me under the Rotherhithe tunnel.... which apparently you can't do in a commercial Defender because it's too heavy. £80 slap on the knuckles. https://instagram.com/bentheoandrews |
15th Apr 2023 10:39am |
The Rotherhithe tunnel was built in about 1910 and l think there's a 2m height restriction as well. Never designed for the motorised behemoths we all drive today.
A large horse weighs around 1,000kg which is just under a ton. Maybe it was designed to take a maximum of a couple of horses and a cart. Last edited by lightning on 15th Apr 2023 11:16am. Edited 3 times in total |
15th Apr 2023 11:07am |
Yeah, seems a bit daft. It's commercials with a GVW over 2T.
https://tfl.gov.uk/modes/driving/rotherhit...cles%20can't%20use,MAM)%20or%20permissible%20maximum%20weight. https://instagram.com/bentheoandrews |
15th Apr 2023 11:10am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Any updates on window activation ........
Had someone asking me about feasibility and want to give correct info |
22nd Sep 2024 12:13pm |
Update after more time has passed, it's definitely better off road than my old Defender in regards to comfort. You don't get thrown around so much! With regards to actual capabilities the old Defender was just as good but required more driver skill. Although the wading depth of the new one is much better in standard specification. |
22nd Sep 2024 12:59pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17492 |
Interest and discriminatory. Why should a private vehicle with a GVW over 2T be allowed in that case? I also wonder what happens with a DPV since although in the same tax class as an LGV it is in the eyes oft he law not an LGV. |
22nd Sep 2024 1:31pm |
Maybe it's because a Commercial Vehicle could be carrying a heavy load, such as a mini skip full of stone, and it would exceed the safe weight limit.
1st Oct 2024 9:56am |
