Home > Puma (Tdci) > Auto conversion |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3639 |
JE engineering do a ZF conversion would be knocking on their door if I had the £££ DEFENDER 90 TDCI XS,
27th Nov 2022 5:54pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7904 |
try the search function, there are several threads with same question. James
28th Nov 2022 12:48pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello Ben01
I've been through the 'Auto Question' in the early part of this year... https://www.defender2.net/forum/topic82722.html My wife wanted to swap her Automatic Land Rover (Freelander) for a Defender... but liked (had got use to) the Automatic 'life style' my research seemed to end up at two main routes, Ashcroft and JE Engineering... Ashcroft offering the LR Range Rover / Disco 1-2 > 4 Speed Automatic Conversion and JE Engineering offering the Ford Electronic 6 Speed Automatic Conversion. My advice would be to approach both companies and test drive a demonstration vehicle. We did take out an Ashcroft Auto Converted 110 for sale (2010 110K Mileage £29K / March 2022) and it actually drove well, so I would not rule out this 'old technology'. I don't have the JE comparison experience and from what I've read I think there would be a significant difference. We decided to not try and find a good Automatic Defender for sale but get a good standard vehicle and then convert as / if required... we ended up with a 2011 110 with 23K Mileage and so far (3K later) the manual gearbox hasn't put my wife off.... so I'm holding my breath https://www.defender2.net/forum/topic83242.html Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
28th Nov 2022 2:01pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3670 |
I’ve got the LOF clutch spring and master cylinder fitted to mine and the clutch is light as a feather. From memory it cost less that £100 for both. Might be worth a try?
28th Nov 2022 6:24pm |
carpetsauce Member Since: 19 Mar 2021 Location: Essex Posts: 58 |
Have a look here. https://www.defender2.net/forum/topic82722.html.
29th Nov 2022 6:35pm |
There's an extra full stop at the end of that link. Here's what it should be:
https://www.defender2.net/forum/topic82722.html Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
30th Nov 2022 7:57am |
