Home > In Car Electronics > DAB Reception lost when ignition is on
Page 2 of 2 <12
Yes, that’s what I would do and everywhere you think suitable around the vehicle.
On mine I had no issue with DAB signal with the Noldens turned on and currently I don’t use ferrite chokes on the headlights, if I had the headlights out of being fitted in situ I would put one on each).
(Different brands probably vary of LED headlights).
However, the LED light bars I have do give off a lot of EMF when turned on they affect DAB and also can cause white noise through my audio system. Ferrite chokes on these very much helped a lot.
So does shielding antenna cable and all joints is beneficial if not even more beneficial than the ferrite chokes.
I would definitely recommend the Nakatanenga DAB aerial, I know that you already have a glass mount one, however, I would definitely think about it even at a later date.
It is good, and in a very hit and miss market reliability is difficult to find.
Nearly every person on here that has the NAK DAB aerial has been happy with it. KEEP CALM AND Drill ON
Post #972280 24th Nov 2022 8:24pm
peanutbob
Thanks for the reply. I’ll get some ferrite chokes and shielding cable initially…if that doesn’t work then over to the NAK aerial . I had the same situation with a 2013 Puma two years ago with an internal aerial and pio unit but I have forgotten if I ever solved it!
Post #972291 24th Nov 2022 9:42pm
The internal DAB aerials are often culprit, known issue really.
Though you may get a bit of improvement out of it anyway after trying those few things. Thumbs Up
Even then, there are various blackspots around whatever antenna you have.
Thumbs Up KEEP CALM AND Drill ON
Post #972312 24th Nov 2022 11:00pm
Page 2 of 2 <12
