Home > In Car Electronics > DAB Reception lost when ignition is on |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 302 |
Thanks for the reply. I’ll get some ferrite chokes and shielding cable initially…if that doesn’t work then over to the NAK aerial . I had the same situation with a 2013 Puma two years ago with an internal aerial and pio unit but I have forgotten if I ever solved it!
24th Nov 2022 9:42pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
The internal DAB aerials are often culprit, known issue really.
Though you may get a bit of improvement out of it anyway after trying those few things. Even then, there are various blackspots around whatever antenna you have. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Nov 2022 11:00pm |
