![]() | Home > Puma (Tdci) > Going from TD5 to Puma |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
Unsurprisingly Ford decided to mount a Ford engine when designing the Puma
I think it's an advantage, because I had my split turbo hose replaced between Christmas and New Year's Eve while overlanding in Spain. Ford parts are always on stock and any van mechanic knows the engine. And it sounds different (with its original chip settings and exhaust). Especially on low rev. I observe many people turning their head because they're interested by its sound. You won't mount any hill in a Ford Transit @ 1200 rpm. But things may change if you have one of these Transit tunings installed on your CPU. |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 928 ![]() ![]() ![]() |
Well what a waste of a day and diesel!
Drove a round trip of 540 miles to look at the 2008 Puma with 114k on the clock only to find that it had been used to launch and recover boats and shunt mobile homes around a holiday site. Chassis was the worst I have seen in a long time and oil leaks from both diffs, gearbox, transfer box, engine and front swivels. To be honest I didn’t even bother starting it, I just pointed out all the leaks and excessive corrosion on the chassis and body to the owner and came home…. The owner purchased the car just over a year ago and appeared not to have any understanding of Landies or mechanics/maintenance. He had spent £2500 on sawtooth alloys and off road tyres when the money should have been spent on the engine, drivetrain and chassis. The only positive is that the car was up in North Wales and we drove through the stunning Snowdonia National Park on the way there and back. Onwards and upwards! Jim |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
I’d always try and buy a car off a forum member. Anyone that is motivated in this forum (or others) generally reads about maintenance and hopefully takes pride in the important bits as well as the shiny thighs.
I have a 110 td5 and a puma (td5 is for sale) I find the TD5 has more space as the dash is further forwards. The 5 gears makes negligible difference in revs and running and as both have been heavily soundproofed there is little difference in noise. The puma has a better heater (by far) but tends to burn your legs. Unless you add a mudstuff plastic thing. The puma dash looks more modern but at the same time does still now look dated compared to a normal car. The puma had more backlash/slack in the drivetrain but now it has the lof intermediate output shaft thing it’s fine. For some strange reason the puma window surrounds seem to rust more. (Or is that just me). I’ve had 3 pumas and all have rotted a bit. The td5s just seem to have been a better paint job. I’m only selling the td5 as the other is a utility that better suits my current needs. TD5 or puma I’d be happy with either. |
