Home > Puma (Tdci) > 2.2 Puma throttle pedal issue |
dannyragsdale Member Since: 06 Oct 2022 Location: Eastern Highlands, PNG Posts: 40 |
I have a similar issue and I'd be curious if anyone has an answer.
24th Nov 2022 11:43am |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
check the low range sensor on the transfer box. when the ecu thinks you are in low it changes the mapping to what you are describing Roaming around ๐ณ๐ด๐จ๐ญ
24th Nov 2022 2:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20441 |
Clutch switch possible, bridge it to see if it is culprit youโll soon know.
If it seems better all of a sudden, leave it bridged or replace clutch switch. I canโt say it is that, but worth investigating as clutch switch cuts torque and can cause a rev hang as well. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
24th Nov 2022 8:56pm |
Finally got around to bridging the clutch switch and made a world of difference. The throttle responds immediately and doesn't hang anymore. Thanks for that tip!
Not sure if it's me getting used to the difference in response now, but the throttle is pulsing now. It doesn't do it all the time, but I either have to put my foot into the throttle or let off completely to not pulse. There doesn't seem to be an in between. Any thoughts on that? Thanks! |
15th Dec 2022 10:38pm |
The Fox Member Since: 24 Mar 2014 Location: Shrewsbury Posts: 94 |
I spent nearly a year tracking down a pulsing throttle on my 2.2. Turned out to be wear on the loom where it comes through under the body, rubbing against the tub. Had worn through and was shorting on the bodywork.
Worth checking out as it was easy to spot once worked out. |
21st Dec 2022 8:36pm |
