Home > Puma (Tdci) > D90 completely dead until battery is tested??
Trussy047
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
I have an intermittent starting issue with my 2010 2.4 D90. After a period of I put the key in the ignition and nothing happened, no lights at all, not even the blinking LED. I turn the key, nothing. I assumed the battery must have a parasitic drain somewhere and be completely dead
However, when I tested the battery with a multimeter the LED started blinking again and the vehicle started first time. The multimeter also showed a healthy battery. This has happened several times since and is rectified with the multimeter.
I've checked other posts that refer to the instrument cluster, etc but my symptoms seem to be different.
I'm thinking ignition switch or maybe immobiliser, any help would be appreciated.
Post #969042 27th Oct 2022 12:33pm
Balvaig
Check for a loose connection at battery. Remove terminals, clean posts and terminals and reseat. Then check connections further along.
It may be that applying multimeter to battery resolves a loose connection.
Post #969044 27th Oct 2022 12:47pm
MK
also check relay connections under the seat. Puma 110" SW
Post #969048 27th Oct 2022 1:38pm
Trussy047
Both good suggestions, I tried those in the first instance. It feels a bit more "electronic", I'm hoping somebody will have had the exact same symptoms.
Post #969049 27th Oct 2022 1:40pm
