Home > Puma (Tdci) > CB Radio
luke11
2008 Defender 110 Puma 2.4 XS DCPU Tonga Green
CB Radio
Where's the best place to fit a CB radio on a TDCI defender so that it's accessible but not in the way or look daft?
Thanks.
Pics would be great!
Post #96637 27th Oct 2011 8:00pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
mines screwed onto the side of the cubby box ,tucked down as far as poss.
Had no problems .. and easy to wire in Guns and Landrovers .... anything else is irrelevant.
Post #96643 27th Oct 2011 8:17pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Mines on the back of the cubby box. Works well as long as you dont need to change channel too often or look at it for any reason.
Post #96653 27th Oct 2011 8:33pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
mines on the front of my cubby, the mike clip screwd to one of the blank switches so as not to put holes in my dash, but my cubby is a non standard size and not sure it would work with a standard cubby.
Post #96655 27th Oct 2011 8:37pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
On the Roof Console :
http://davidecorsetti.files.wordpress.com/...-radio.jpg
http://www.roverworld.com/roof_console_english.htm Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #96723 28th Oct 2011 8:00am
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
I mounted my remote head Uniden UHF unit on a ply insert I bolted to the underside of the cubby box. That way I have not had to drill into the dash or other areas. The main box is under the driver seat with a remote speaker fitted to the right of the head. The speaker could easily be hidden behind the dash if required.
Will have to change it in the next few years as we are going to 80 channel UHF.
Post #96730 28th Oct 2011 8:45am
Happyoldgit
Side of the cubby box secured with double sided body tape direct to the body of the rig. Power straight from the battery and feed cables via grommet in the seatbox. Steve.
http://forums.lr4x4.com
Post #96738 28th Oct 2011 9:32am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
On this one I bought a secure cubby box and mounted it in that so it could belocked away.
On the defender before that one I mounted it on the rear of the factory fitted cuby box.
Boy
Post #96752 28th Oct 2011 11:02am
bob neville
same as The Boy, MSS cubby box Thumbs Up
Bob
Post #96753 28th Oct 2011 11:07am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Is that some kind of time machine mounted to the front of it?
I'd try the same, but Td5s won't do 88mph Laughing
Post #96754 28th Oct 2011 11:10am
The Boy
Na its a marine switch pannel that controld the extra lights/fridge/worklights ect.
If it had been a time machine I would have gone back and NOT bought that perticular land rover Neutral
Boy
Post #96759 28th Oct 2011 11:20am
JSG
Bob
I used the MSS route in the Tombraider 90 - but they won't fit the Pumas unless you lose the cup holders which I NEED for my coffee Laughing John
2011 Tdci 110 CSW XS
Post #96760 28th Oct 2011 11:26am
bob neville
John
I drilled new holes in the cubby box floor and moved it back a couple of inches. Does not protrude into the rear foot area too much and I can now use the cup holders Thumbs Up
Bob
Post #96764 28th Oct 2011 11:37am
JSG
Hmm, bit late now as I fitted a Nak under cubby safe.
Good idea though - should have thought of trying that before Laughing John
Post #96767 28th Oct 2011 11:46am
