![]() | Home > Puma (Tdci) > Help with a constant live fuse |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Fuse 5 is a better bet, as this only affects the 12V permanent feed to the rear socket (where fitted - it's not on all 2.2s)
![]() ![]() Last edited by Martin on 30th Sep 2022 12:27pm. Edited 1 time in total |
Clifford the Big Red Defender Member Since: 30 Sep 2022 Location: Somerset Posts: 9 ![]() ![]() ![]() |
Amazing Thank you!
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
just in case its a tracker your fitting ![]() ![]() |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1094 ![]() ![]() ![]() |
fun fact:
I just googled the code at the bottom of the fuse box label, because I was curious what it was related to (other than the label itself ![]() Second search result was this thread. Why is that interesting? Well, there is no mention in the code in the TEXT of this thread. It's only in the IMAGE - so google must do an OCR on images. I didn't knew that. Also the other thread here where the label is shown comes up in the search. |
