Home > Puma (Tdci) > Help with a constant live fuse
Clifford the Big Red Defender
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi All,
New to the defender world and I need to install a component that comes off a constant live fuse.
Any idea which of the fuses will be appropriate? Currently, have it in F1 which I think is right.
-C
Post #966304 30th Sep 2022 12:02pm
Martin
Site Admin
Fuse 5 is a better bet, as this only affects the 12V permanent feed to the rear socket (where fitted - it's not on all 2.2s)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #966306 30th Sep 2022 12:19pm
Amazing Thank you!
Post #966307 30th Sep 2022 12:27pm
nitram17
Re: Help with a constant live fuse
Clifford the Big Red Defender wrote:
Hi All,
-C
just in case its a tracker your fitting Wink Wink try to disguise the wire the best you can!
Post #966340 30th Sep 2022 7:47pm
Wink thanks for the heads up
Post #966349 30th Sep 2022 9:14pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
fun fact:
I just googled the code at the bottom of the fuse box label, because I was curious what it was related to (other than the label itself Smile)
Second search result was this thread. Why is that interesting? Well, there is no mention in the code in the TEXT of this thread. It's only in the IMAGE - so google must do an OCR on images. I didn't knew that. Also the other thread here where the label is shown comes up in the search.
Post #969962 4th Nov 2022 5:08pm
