Home > Puma (Tdci) > New clutch. New rattle |
itsdashy Member Since: 20 May 2021 Location: Reading Posts: 72 |
Just had the clutch and front brakes changed as a £1.2k precaution and I now have this rather noisy rattle at idle.
https://youtu.be/2s0h8EGhwPY It disappears when the pedal is depressed and when revved to 2k+ any ideas? Forgot to say the output shaft was replaced and greased at the same time. All clunking has vanished. |
15th Sep 2022 1:48pm |
Racedriver Member Since: 24 Jan 2019 Location: Buckinghamshire Posts: 113 |
Did you change the dual mass flywheel?
15th Sep 2022 3:43pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3643 |
what clutch plate did you use many create a worse rattle than the original LR ones DEFENDER 90 TDCI XS,
15th Sep 2022 4:48pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 |
Due to higher rate springs at the hub. Puma 110" SW
15th Sep 2022 7:55pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1845 |
Yep, mine’s a slightly tweaked 300Tdi, so I went for the LOF powerspec (I think) - uprated anyway.
When the gearbox is cold - no noise; when it warms up and the oil thins, it chatters away. I got in touch with Luke at LOF and Dave Ashcroft (who’d supplied a rebuilt gearbox) and am told it’s just one of those things, but that it will do no harm. Just the gears chattering together, but not wearing. I’ve pondered a sound deadening blanket but not got too bothered yet. As in the OP it’s only when idling that it’s an issue. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
16th Sep 2022 9:42am |
It was just a case of it bedding in. All rattles have gone thankfully.
8th Aug 2024 10:53am |
