Home > Puma (Tdci) > New clutch. New rattle
itsdashy
United Kingdom 2012 Defender 90 Puma 2.2 PU Orkney Grey
Just had the clutch and front brakes changed as a £1.2k precaution and I now have this rather noisy rattle at idle.
https://youtu.be/2s0h8EGhwPY
It disappears when the pedal is depressed and when revved to 2k+ any ideas?
Forgot to say the output shaft was replaced and greased at the same time. All clunking has vanished.
Post #965127 15th Sep 2022 1:48pm
Racedriver
United Kingdom 2015 Defender 110 Puma 2.2 USW Indus Silver
Did you change the dual mass flywheel?
Post #965140 15th Sep 2022 3:43pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I don't think any of the Puma Defenders have a Dual Mass flywheel?
How many miles has it done since you changed the clutch?
Which clutch was fitted? I understand a lot of the uprated clutches tend to rattle at idle. There's quite a few threads on here about it.
Post #965144 15th Sep 2022 4:06pm
LR90XS2011
what clutch plate did you use many create a worse rattle than the original LR ones DEFENDER 90 TDCI XS,
Post #965148 15th Sep 2022 4:48pm
MK
Due to higher rate springs at the hub. Puma 110" SW
Post #965170 15th Sep 2022 7:55pm
donmacn
Yep, mine’s a slightly tweaked 300Tdi, so I went for the LOF powerspec (I think) - uprated anyway.
When the gearbox is cold - no noise; when it warms up and the oil thins, it chatters away.
I got in touch with Luke at LOF and Dave Ashcroft (who’d supplied a rebuilt gearbox) and am told it’s just one of those things, but that it will do no harm. Just the gears chattering together, but not wearing.
I’ve pondered a sound deadening blanket but not got too bothered yet. As in the OP it’s only when idling that it’s an issue. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #965207 16th Sep 2022 9:42am
itsdashy
It was just a case of it bedding in. All rattles have gone thankfully.
Post #1042215 8th Aug 2024 10:53am
