![]() | Home > Td5 > Will this roof fit a TD5 110 MY2001 |
Yes, it'll fit your TD5. They're the same right up to the end of production and are interchangeable with earlier models bar re-drilling a few holes, as the basic dimensions of the vehicle are unchanged throughout. Darren
Meta87 Member Since: 05 Aug 2022 Location: Innsbruck Posts: 22 ![]() ![]() |
Thanks for your reply. Will the holes fit the the B post, window frame and upper rear panel right away? The reason I‘m asking is because my 110 had a rollover and therefore I need a roof to correctly bring the B posts and window frame back to its exact position as it seems they have slighlty travelled.
Yes, this didn't change between TD5 and Puma. Darren
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6122 ![]() ![]() ![]() |
I fitted an early (external ribbed roof) onto my 110 when I built it using Td5 era B pillars, everything all lined up.
In fact I don't think I redrilled any holes on it at all. |
