Home > Td5 > Will this roof fit a TD5 110 MY2001
Meta87
Austria
Hi,
I found a 110 roof nearby and can‘t find out if it’s gonna fit my 110 MY2001. The information on this topic (different dimensions etc) seems rather scarce. Can anybody figure out what type of roof this is (TD4?) and if it is going to fit on my model? What adjustments would be necessary if not?
As always thanks in advance!
(I only got those photos from the seller)
Post #964679 11th Sep 2022 9:37pm
Yes, it'll fit your TD5. They're the same right up to the end of production and are interchangeable with earlier models bar re-drilling a few holes, as the basic dimensions of the vehicle are unchanged throughout. Darren
Post #964684 11th Sep 2022 10:06pm
Meta87
Austria
Thanks for your reply. Will the holes fit the the B post, window frame and upper rear panel right away? The reason I‘m asking is because my 110 had a rollover and therefore I need a roof to correctly bring the B posts and window frame back to its exact position as it seems they have slighlty travelled.
Post #964695 12th Sep 2022 6:58am
Yes, this didn't change between TD5 and Puma. Darren
Post #964711 12th Sep 2022 8:51am
I fitted an early (external ribbed roof) onto my 110 when I built it using Td5 era B pillars, everything all lined up.
In fact I don't think I redrilled any holes on it at all.
Post #964769 12th Sep 2022 5:14pm
