![]() | Home > Technical > 2015 defender Handbrake |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 541 ![]() ![]() |
Remove rear propshaft and handbrake drum, have a look at the handbrake shoes.
You will probably get away with adjusting them or replacing them, it depends how much heat you generated, at worse case it could have warped the brake drum(very unlikely) or cooked the rear output seal. |
201590s Member Since: 13 Aug 2022 Location: Dubai Posts: 8 ![]() ![]() ![]() |
Thank you for the reply.. the smell was like a burning wire
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
I once drove 150 miles while towing a caravan with the handbrake on due to the handbrake expander failing and locking the shoes on. I did notice a slight lack of power. I must also point out that part of that journey was up Shap on the M6 the highest section of motorway in the country and a constant climb.
When I arrived at the caravan site and whilst unpacking I noticed that the handbrake drum was glowing Oh **** I thought. To cut to the chase the next day I took to the Land Rover to an independent garage located nearby and the result was no damage, he advised changing the shoes though which I agreed he also fitted a new expander. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
That’s quite a tale Gilarion - and very reassuring!
Glad it wasn’t as bad as you thought and exclaimed - which should also provide some comfort to the OP ![]() |
Thank u guys for the replies that cleared my mind
Can u guys please mark for me what needed to be replaced in that picture Thank u |
Please see the attached picture
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
do you mean the picture in your gallery?
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 834 ![]() ![]() ![]() |
Have you caused any oil leaks (due to cooked oil seal)?
If not, check shoes still have some brake material left and rough up with some emery paper. Adjust to get a good bite point and check the brake works properly. If this is all good then no need to change anything. |
I really appreciate ur feedbacks guys
Yes the picture in my gallery |
Thank u no there is no oil leak at all i only drove it for 200 - 300 m I reached up to 90km/h then I slowed down when I started to smell the smoke when I stopped I saw the cabin with a smoke it smells like a burning wires |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 323 ![]() ![]() ![]() |
Good point re oil seal, I'd be checking the levels just in case. I too managed to drive about 2 miles with the handbrake on and cooked the rear output oil seal on the transfer box. |
So u only had to change the oil seal no other things?
The oil seal was the only thing required but I fitted a whole new flange kit while it was apart as the OEM kit (genuine parts in a white box) was not a lot of money. Did an oil change while I was at it. Oil leak stopped, transfer box survived many years with no leaks before becoming noisy due to a bearing, I don't link the two issues though. The truck lead a very hard life before I owned it and the transfer box did 117,000 miles.
Thanks a lot for these info’s I’ll check that and see what I’ll find
