Home > Technical > Puma Instrument Cluster and Mileage |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1081 |
um, it‘s not supposed to be easy
Also AFAIK the instrument cluster is part of the immobiliser system. Again, not supposed to be easy to manipulate. I‘d be surprised if your Puma will run with that other cluster. |
7th Aug 2022 6:24pm |
mmddbb Member Since: 15 Sep 2021 Location: UK Posts: 13 |
Hi macfrank
It starts and runs fine, just displaying the donor car’s mileage. It would seem more logical to tie the mileage into the ECU, as the cluster is an easy swap, and the clusters themselves must pack up from time to time. |
7th Aug 2022 6:36pm |
Ok, I‘m surpised. Watching with interest..
7th Aug 2022 7:10pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17435 |
You need a suitable diagnostic system to update the CCF. From the WSM:
Click image to enlarge |
7th Aug 2022 7:35pm |
Thanks blackwolf, that’s very helpful.
8th Aug 2022 12:13am |
„the CCF contains … immobilization codes …“ That‘s what I meant. So how can the engine run with a different unit? :-/ |
8th Aug 2022 6:23pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2028 |
According to Pete Bell at BAS the Instrument pack is the master store for the VIN as part of the CCF
See this post https://www.defender2.net/forum/topic40550...p;start=30 Top of the page, from Pete you can see a post from him, the point to note is this statement. “For reference and info... The vin from the instrument pack is transmitted on the CAN nework to the engine ecu and diag port, the engine ecu does not output a vin nunber diagosticlly its self and so only reports/mirrors what is ever inside the instruemnt pack its self in its own way. Even sending an 8 byte request command on CAN addressed directly to the engine ecu on network address 0XE0 command of 03 22 F1 90 00 00 00 00 to request to read VIN will still only ever report the vin seen on the CAN network thats outputted by the instrument pack it self and nothing more. ” It would be interesting to know if the correct VIN is also showing with the new instrument pack or whether the donor vehicles vin is now showing. |
8th Aug 2022 7:36pm |
Do we conclude from this that is actually almost as easy to clone a Puma as it is to steal it, just fit the VIN plate and binnacle from another vehicle? Shocking!
8th Aug 2022 10:00pm |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
I've converted my td5 interior to full Puma spec including the dashboard and instrument cluster, using some of the wizardry offered by Martin who runs this forum.
I bought a used Puma instrument cluster from ebay, bought a new perspex cover for it and then used digidash who are local to me to set the mileage in the Puma unit to exactly the same as in my original. If you search for mileage correction you will find someone to do it. Clearly these services can be abused and I'm not advocating them, but it got me the result I wanted A long way of saying the mileage is definitely stored in the instrument cluster and you can change it if you want! Of course my car is a TD5 so maybe the Puma immobiliser etc makes it more complicated! |
9th Aug 2022 11:05am |
Thanks for all the replies. I will take a look at mileage correction but given the interaction with the immobiliser and VIN I may just dismantle the original cluster and treat the first one as a test run!
11th Aug 2022 5:00pm |
I think the CCF , including immobilisation codes, may be stored in the ECM and instrument cluster and shared between them via the HS CAN bus, however they are only used in the ECM. The Alarm module, be it the 10AS or later ALM, communicates directly with the ECM via a separate dedicated serial bus. This bus goes via the instrument cluster but the instrument cluster does not participate in the conversation. |
3rd Oct 2022 11:54pm |
