![]() | Home > Maintenance & Modifications > Front Brake Discs and pads |
You couldn't pay me to put EBC pads in my cars again, I had a set of Green Stuff explode in the caliper of my MINI.
I've been running LOF road spec for a year now and I'm very impressed with them, I tow 3.5 tonnes a fair bit as well. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4262 ![]() ![]() ![]() |
My understanding is that they shouldn’t be testing Defender on the brake rollers for MOT as it can damage the centre diff. Can anyone confirm this? Also, I don’t like the idea they used the handbrake to enhance the result. 2007 110 TDCi Station Wagon XS
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
I never used EBC, hence asking, but exploding pads is not something I would like to experience.
Agree, I also do not like it being tested on brake rollers, as you say, due to the center diff. But I do not have much options. I had found one tester that drives the Defender on a test pad, but the tester himself had such a strange personality that I preferred to sacrifice the center diff 😢 Technically they still have to test the hand brake... I warn my current tester every time to go gentle with that, and his reply is always ‘yes I know, I know its a transmission brake’. I think I see the brake lights coming on when he is testing the hand brake. Btw, as I mentioned earlier that I want to go the extra mile with braking efficiency, actually I want to stop within a mile ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
I’ve had the opposite experience with EBC; On my Polo G40 ran EBC Greenstuff pads both F&R with grooved and dimpled discs, very progressive, no exra noise, just quite dusty. On my SAAB 93 Viggen Coupe have run both Redstuff (Low Dust) and Yellowstuff pads with both GD and just grooved discs on both F&R even with upsized rear disc & caliper combo ![]() ![]() On my Nissan Patrol SWB Y61 ran Blacktuff (Ultimax) better than OEM both on price and performance I had only one problem with an older set of front Redstuff pad that were left in the Viggen, they suffered from “rustjacking” where corrosion sets in between the pad material and the steel pad backing, the car had been left outside from October to February, uncovered, unmoved and unprotected, while the Patrol was my daily driver in winter. EBC immediately replaced both F&R sets of pads with a choice of my flavour, DHL’ed next day. ![]() Great customer service and would recommend to anybody, once the pad set in the 110 needs renewing from the LOF set currently, EBC any day. ![]() www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
