Home > Maintenance & Modifications > Terminal removal
rustandoil
Terminal removal
I need a little bit of help.... How do I remove the terminals from this housing?
Post #960212 1st Aug 2022 4:31pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Sorry, no idea it's not one I've come across, but you need to click the image in your gallery after uploading it to get it to show up on posts.
Post #960222 1st Aug 2022 5:29pm
rustandoil
It's the connector that goes to the fuel pump and sender
Post #960226 1st Aug 2022 5:45pm
Procta
from my experience with messing about with loom connectors in the past, is that a very small flat head at the back of the plug normally releases the little terminals. but take photos before you disturb it. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #960482 4th Aug 2022 2:00am
rallysteve
Move the slide latch across on the face of the connector (looks like it already is on your picture) then just firmly push the terminals out of the back of the connector. You just need something the same diameter of the terminals to avoid damaging them
Post #960489 4th Aug 2022 8:13am
Martin
Site Admin
You will need a tube type removal tool to push the terminal tangs in. Simply pushing on the terminals will wreck them and possibly the housing too.
I have in the past (where no removal tool was available) used a piece cut from an aluminium drinks can, wrapped around a suitably sized Pozi screwdriver to make a tube for removing terminals like these.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #960516 4th Aug 2022 1:26pm
rustandoil
Thanks for the replies.... I did as Steve said, and it seems that i might have got away without causing damage as per Martins reply.... I did have to squirt a little WD40 to release the seals that seem to have stuck themselves to the housing.
Thanks to all Bow down
Post #960562 4th Aug 2022 6:20pm
