Home > Maintenance & Modifications > Terminal removal |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 751 |
I need a little bit of help.... How do I remove the terminals from this housing?
1st Aug 2022 3:31pm |
Click image to enlarge It's the connector that goes to the fuel pump and sender Click image to enlarge |
1st Aug 2022 4:45pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5204 |
from my experience with messing about with loom connectors in the past, is that a very small flat head at the back of the plug normally releases the little terminals. but take photos before you disturb it. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
4th Aug 2022 1:00am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Move the slide latch across on the face of the connector (looks like it already is on your picture) then just firmly push the terminals out of the back of the connector. You just need something the same diameter of the terminals to avoid damaging them
Steve 02' 110 TD5 Double Cab Rebuild Thread |
4th Aug 2022 7:13am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
You will need a tube type removal tool to push the terminal tangs in. Simply pushing on the terminals will wreck them and possibly the housing too.
I have in the past (where no removal tool was available) used a piece cut from an aluminium drinks can, wrapped around a suitably sized Pozi screwdriver to make a tube for removing terminals like these. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
4th Aug 2022 12:26pm |
Thanks for the replies.... I did as Steve said, and it seems that i might have got away without causing damage as per Martins reply.... I did have to squirt a little WD40 to release the seals that seem to have stuck themselves to the housing.
Thanks to all Click image to enlarge |
4th Aug 2022 5:20pm |
