Home > Maintenance & Modifications > 300tdi maintenance |
big ives Member Since: 24 Dec 2013 Location: Northern Ireland Posts: 125 |
300tdi
engine oil Castrol 10w40, but I buy this from a farm supplier in 20ltr drums works out cheaper gearbox R380 I use westway MTF 94 transfers and diffs comma EP80/90 hope this helps 2016 Discovery 4 1989 90 CSW V8 (fully rebuilt and running like a dream) 1996 defender tray back fully rebuilt/loaded for challenge events |
24th Jul 2022 12:02pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1222 |
It's a rudimentary engine. It'll benefit more from more frequent oil changes than any fancy oil.
I just buy it from the local tractor factors in bulk. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
24th Jul 2022 12:34pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6093 |
I'm sure Opie oils still do deals, and/or a complete "kit" of oil that's needed.
24th Jul 2022 2:34pm |
APK Member Since: 13 Jan 2015 Location: London Posts: 255 |
big ives, sako243, diesel_jim
APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
25th Jul 2022 7:07am |
Hi all,
Looking through the stack of invoices I received when I purchased my 300tdi last year, I noticed that 5w30C3 fully synthetic was used instead of 10w40 which was the case with previous services. May I know if any harm could come to the 300tdi engine with the continued use of 5w30 instead of 10w40? Reason I ask is because my Puma uses 5w30 and it just saves me from keeping two different types of engine oil for top-ups. Many thanks! Kind Regards APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
31st Jul 2022 12:21pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4700 |
It should not do any harm. The trouble is keeping it in! It is very fine and your engine was not designed for such fine oil. You were charged a lot more for oil than you needed to pay. 10W-40 semi synthetic is as fancy as this engine needs.
I remember my series 111 was in getting work done on it so I asked them to do an oil and filter change while it was up on the ramp. They used 5W-30! Well it was coming out of every seal it could find. Even when I changed it with 15W-40 mineral oil it took a while to seal up. Also the oil pressure light was coming on a lot. If you stuck for topping up the tdi you could use the 5W-30 as it will be in relatively small amounts. The Puma on the other hand must have the 5W-30. It will not cost a lot to keep a one litre bottle of 10W-40 in the tdi for top ups. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
31st Jul 2022 10:56pm |
Thank you for the advice. I have noticed a patch of oil every time I park and this may be the reason. APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
1st Aug 2022 3:44pm |
Just drain it and refill. Do the filter aswell as that holds oil. You could lie underneath and see where the leak is. It could be a sump plug or bung that needs changed, you will see oil around this if it is needing to be changed but you will have to drain the oil to do it. There were two sizes of drain plug or bung fitted to the 300 tdi. Earlier ones took the large one or same as the 200 tdi where as later ones took the smaller one fitted o the Td5 engine. My daughter's 300 tdi is one of the last from 1998/99 and it takes the smaller bung
Check around the oil filter where it mates to the engine. Sometimes a bad seal can lead to a leak. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
1st Aug 2022 6:28pm |
Looks like its dripping from the filter. Thanks again. Is ERR3340 MAHLE OC261 a good filter? Kind Regards Click image to enlarge APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
1st Aug 2022 10:43pm |
Yep MAHLE is a good filter which I use myself. It could be just down to the very fine 5W-30. You could remove the filter, clean the mating surface and smear the rubber sealing ring with some fresh oil, then refit it. Put a container underneath to catch what ever oil comes out. If you are worried about the filter you could change it but Mahle are a decent filter. There are good instructions in your hand book about this . It is hand tightened. I'll put the handbook instructions up if you want them. 1982 88" 2.25 diesel
2nd Aug 2022 9:41am |
Click image to enlarge If you do change the filter you will need to top up the engine oil as there will be some in the filter. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
2nd Aug 2022 12:09pm |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 359 |
When I bought my 2006 300Tdi, second hand in 2012, it ran on 5W30. It also stated so in my owners manual. As here in sun South Africa it gets a bit hotter than up in Europe, I decided to go to 5W40. I have no problems and here's a picture of my lifters just to Bragg a bit. Click image to enlarge |
2nd Aug 2022 7:22pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 814 |
I thought it was normal to run the thinner viscosity oils in colder climates to prevent it getting too thick in the low temps?
The 3340 filter is the one you want, I buy genuine as it is a minor cost hike over second source variants and worth piece of mind rather than trying to guess who makes decent filters or not! If your filter is leaking try nipping it up a bit by turning it by hand before resorting to removing it. It has a big old seal on it and I would be surprised if a correctly tightened filter is sufficiently compromised to give a visible leak. |
2nd Aug 2022 7:56pm |
spudfan, jfh, I Like Old Skool,
Thank you for your comments, much appreciated Q1 - The plug is replaced each time the oil is replaced in the Puma, is this good practice with the 300tdi as well? Q2 - Any idea why the fuel filter was moved from the engine bay area in the 300tdi, to the off-side rear wheel area in the Puma?
Q3 - May I know if there is a way to tell which size drain plug, so I can order the part before removing? Thank you APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
4th Aug 2022 12:49am |
