Home > Maintenance & Modifications > 300tdi maintenance
Page 2 of 2 <12
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
1. Not necessary but the washer is.
2. I am not sure.
3. Mine is the later type. The plug head is approximately 15mm.
Post #960483 4th Aug 2022 3:10am
spudfan
Ireland
Changing the sump plug washer is a good idea. The early 300 tdi is the same as the 200 tdi and is 27 mm across. The later 300 tdi is smaller and is. The washers come in packs of ten and are very cheap.I am sorry that is the best I can do but someone else should have more specific knowledge. If in doubt buy both as they are very cheap!
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #960518 4th Aug 2022 12:41pm
APK wrote:
Q2 - Any idea why the fuel filter was moved from the engine bay area in the 300tdi, to the off-side rear wheel area in the Puma?
That move was actually made with the TD5 and just continued with the Puma. It's probably just for packaging reasons. Darren
Post #960614 5th Aug 2022 6:31am
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
jfh, spudfan, LandRoverAnorak
Once again, many thanks for your comments
I finally got a chance to look underneath.
1) The head plug looks to be around 20mm (pic 1). I assume this is the smaller of the two (27mm vs 15mm)?
2) Please share sump plug washer Part# if readily available
3) I am seeing an opening in what looks like the gearbox (red circle in pic 2), but on the diagram the drain plug is located elsewhere (pic 3) and this area should not have an opening.
May I know what this is and is it meant to be open? Shocked
Thank you!
 APK
MY2016 110 Adventure Corris Grey
MY1997 110 County Station Wagon 300 Tdi Alpine White
Post #960693 5th Aug 2022 4:43pm
spudfan
Ireland
The circle red is a drain hole for the bell housing. Leave it as it is. You usually get a screw in bung called a wading plug with the Land Rover to screw in when deep wading.
https://www.ebay.co.uk/itm/291484638304?ha...SwU9xUMFiU
This looks to be the sump plug you need
https://www.ebay.co.uk/itm/370865996814?fi...xys4RR990e
Contact them and just get a packet of sealing washers 1982 88" 2.25 diesel
Post #960704 5th Aug 2022 5:12pm
jfh
As said above.
The part number for the washer I use is: ALU1403L
Post #960712 5th Aug 2022 5:26pm
APK
Thank you Thumbs Up APK
Post #960757 5th Aug 2022 11:15pm
APK
Are these the wading plugs J688 and J687?
They look different in shape in the Owners handbook (J688 looks like a hexagon and J687 looks like a square head) but the x2 I have in the toolkit look identical. I assume they are aftermarket?
Thank you!
 APK
Post #962627 23rd Aug 2022 1:28pm
spudfan
Ireland
Look fine 1982 88" 2.25 diesel
Post #962630 23rd Aug 2022 2:03pm
APK
jfh wrote:
When I bought my 2006 300Tdi, second hand in 2012, it ran on 5W30.
It also stated so in my owners manual.
As here in sun South Africa it gets a bit hotter than up in Europe, I decided to go to 5W40.
I have no problems and here's a picture of my lifters just to Bragg a bit.
Yes, just realised that the Owners Manual shows many more options that the Workshop Manual. Thanks for pointing that out.
Workshop Manual
Owner's Manual
 APK
Post #962734 24th Aug 2022 11:06am
APK
Hi all,
Dealer recommended Castrol SAF-X0 Oil Fluid TYK500010 (£30.95 per litre) for Transfer gearbox and differentials.
https://rimmerbros.com/Item--i-TYK500010
Is Castrol TRANSMAX Universal LL 75W-90 a better choice at £17.95 per litre, GL-5 and fully synthetic?
https://www.opieoils.co.uk/p-77373-castrol...fluid.aspx
7l in total required for transfer gearbox (2.3l) and front & rear differentials (1.7l + 2.3l).
Thank you APK
Post #963008 26th Aug 2022 6:50pm
jfh
That type of oil in the diffs is not necessary.
A good quality EP90 will be just fine.
I used to have Transmaxs 75w90 in the transfer box but I am also starting to think it's too much.
Post #963017 26th Aug 2022 8:04pm
Page 2 of 2 <12
