Home > In Car Electronics > Td5 90 XS rear speakers not working
Waldo
Problem is as above:
My td5 90 xs rear speakers are not working.
Is anyone able to give me a steer on the direction the wiring loom takes so I can check it? Also what's the best way to check you're getting a feed through multimeter wise etc.
Any other advice also appreciated.[/b] Defender 90 XS TD5 (03 Reg)
Post #959237 23rd Jul 2022 5:39am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Best way to start would be remove the speaker panels, pop out the radio and do a continuity check with a multimeter between the plug at the radio end and the connectors at the speaker end. This will tell you if there is a break in the wires anywhere and which direction the loom goes (downwards into the main harness or upwards into the roof lining). It's odd that you have lost both speakers but you don't mention any other issues with electrics at the rear of the vehicle. For both speakers to stop working you'd need at least two broken wires and it would be odd that if there is loom damage that only speaker wires are damaged.
Would be quite easy to check the speakers are Ok by taking one of the rears and connecting to the front wiring. Don't overlook that fact that the radio could also have failed on the rear channel amp. I guess you've checked the fader has not been tampered with?
Post #959468 25th Jul 2022 1:19pm
Waldo
Mega, thanks for the advice. Hopefully will get to look at it this weekend! I'll start with a simple speaker switch and see.
Fader is set equal front and rear.
I did change the head unit for a blaupunkt nurnberg 200 pro about 3 months ago with the appropriate adapters. what I'm not sure of is if they were working before (99% sure they were fine).
Typically the old head unit is in Manchester and I'm now in France but normally London! Defender 90 XS TD5 (03 Reg)
Post #959604 26th Jul 2022 4:25pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Could be the pins aren't in the right places for the new head unit or you have different channel outputs
Post #959621 26th Jul 2022 6:35pm
