Home > Maintenance & Modifications > Leaking Rear Diff
ChrisDefender
Leaking Rear Diff
Hi,
I have a rather wet rear diff on a 2011 90.
Can you anyone tell me if I need to change all the parts circled in red on the illustration below, or is there likely to be one main culprit Confused
Could do with having all the required parts to hand before starting the job as I need it done in one hit!
Many thanks in advance.
Post #958443 15th Jul 2022 4:17pm
spudfan
Ireland
The leak will be from the 5,10,11,12 bits. Just replace the lot. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #958446 15th Jul 2022 4:55pm
ChrisDefender
Adds up to quite a bill for genuine parts! Just over £200. Sad
Post #958448 15th Jul 2022 5:02pm
markb110
Don’t forget to check that the breather tube isn’t blocked or been crushed asomewhere along it’s length…
Post #958450 15th Jul 2022 5:06pm
ChrisDefender
Thumbs Up Thank you.
Post #958451 15th Jul 2022 5:10pm
spudfan
Ireland
There are decent non genuine parts out there. This might not be your particular model but just an example of the cost
https://www.advancedfactors.co.uk/rear-2-p...0927-c.asp 1982 88" 2.25 diesel
Post #958452 15th Jul 2022 5:11pm
Dinnu
If the seal area of the drive flange (13) is not pitted or severely gloved, then just change the oil seal (12). Why replace otherwise good parts? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958455 15th Jul 2022 5:45pm
^^^ This. 12 and possibly 13 is all you need. You can't replace the bearing without stripping the diff (you can't remove the outer race with the pinion in place).
Post #958462 15th Jul 2022 6:38pm
Check the prop shaft UJ’s too, as one of these had failed on mine and caused a rear diff oil leak. Had it repaired and the leak came back and only after that did it get noticed it was a prop shaft UJ and no one noticed it but me deliberately checking for it and you could barely tell unless the prop shaft is off. KEEP CALM AND Drill ON
Post #958480 15th Jul 2022 9:19pm
ChrisDefender
Thanks for all the replies chaps, very helpful Thumbs Up Thumbs Up
Post #958690 18th Jul 2022 7:46am
