![]() | Home > Maintenance & Modifications > Smoked LED Lights Total Look for SVX |
DEF_Jam Member Since: 17 Jul 2011 Location: Milan Posts: 59 ![]() ![]() ![]() |
For the rear of the car I've just found these, may just need to play with the connections a little bit.
https://www.ebay.it/itm/253756089620?hash=...Sw7RBhNOCv Can't find any front smoked indicators and high-beams. It seems like for aftermarket SVX grille they are all swapping position of indicators and high-beams. Originally SVX has indicators on top corners and high-beams at the bottom. |
I don't think I've ever seen aftermarket lights, smoked or otherwise, for the SVX front end. It's a very niche arrangement and frankly, not widely loved. Darren
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
I saw these : https://www.mobilecentre.co.uk/svx-fire-ic...-indicator supplied by Hella, so they might be available in Italy from one of the Hella distrubutors closer to you.
To tint them dark / smoke I would use a tint film that is removable : https://www.xpel.com/products/headlight-protection-film so that if the Carabinieri do get funny you can remove it. Good luck Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello DEF_Jam
Smoked Front & Rear 95mm (NAS) Side Lights + Indicators + Fog Light + Reverse Light https://defenderupgrades.co.uk/product/lan...-10pc-kit/ Smoked 95mm (NAS) Fog Light https://defenderupgrades.co.uk/product/def...ight-95mm/ Smoked 95mm (NAS) Reverse Light https://defenderupgrades.co.uk/product/def...ight-95mm/ Smoked Front & Rear 73mm Side Lights + Indicators + Repeaters + Number Plate (if you need smaller side lights to fit KBX light surrounds) https://defenderupgrades.co.uk/product/lan...73mm-leds/ SKIP https://www.defender2.net/forum/topic83242.html |
Skip, the OP is talking about an SVX front end rather than a KBX one, which are very different things. Darren
Hello LRA
Point taken... ![]() You can complete this direction with E and DOT type approved Smoked LED Headlights... https://www.originalcaferacer.com/product/...110-black/ ![]() Click image to enlarge ![]() Each to their own... probably works best on a dark Defender... ![]() https://www.defender2.net/forum/topic83242.html |
