Home > Maintenance & Modifications > Smoked LED Lights Total Look for SVX
DEF_Jam
Italy 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Dear team,
I hope you are all doing well.
I'm working on a 110 SVX that was unfortunately mistreated by old owner.
Lights are all wrongly replaced (rear has standard Wipac LED where SVX has originally NAS style, they replaced reverse light with small Wipac Shocked ).
As I'd like to go for a new "stealth" look for the car but I'm finding hard to find all smoked LED lights for front and rear ends.
Is there any front indicatore LED smoked for SVX? Smoked high beams?
Post #958261 14th Jul 2022 10:10am
DEF_Jam
For the rear of the car I've just found these, may just need to play with the connections a little bit.
https://www.ebay.it/itm/253756089620?hash=...Sw7RBhNOCv
Can't find any front smoked indicators and high-beams.
It seems like for aftermarket SVX grille they are all swapping position of indicators and high-beams.
Originally SVX has indicators on top corners and high-beams at the bottom.
Post #958292 14th Jul 2022 1:54pm
I don't think I've ever seen aftermarket lights, smoked or otherwise, for the SVX front end. It's a very niche arrangement and frankly, not widely loved. Darren
Post #958297 14th Jul 2022 2:40pm
The Zee
I saw these : https://www.mobilecentre.co.uk/svx-fire-ic...-indicator supplied by Hella, so they might be available in Italy from one of the Hella distrubutors closer to you.
To tint them dark / smoke I would use a tint film that is removable : https://www.xpel.com/products/headlight-protection-film so that if the Carabinieri do get funny you can remove it.
Good luck Zaid-M
www.DefencePhotos.com
Post #958320 14th Jul 2022 5:34pm
X4SKP
Hello DEF_Jam
Smoked Front & Rear 95mm (NAS) Side Lights + Indicators + Fog Light + Reverse Light
https://defenderupgrades.co.uk/product/lan...-10pc-kit/
Smoked 95mm (NAS) Fog Light
https://defenderupgrades.co.uk/product/def...ight-95mm/
Smoked 95mm (NAS) Reverse Light
Smoked Front & Rear 73mm Side Lights + Indicators + Repeaters + Number Plate
(if you need smaller side lights to fit KBX light surrounds)
https://defenderupgrades.co.uk/product/lan...73mm-leds/ SKIP
Post #958324 14th Jul 2022 5:58pm
Skip, the OP is talking about an SVX front end rather than a KBX one, which are very different things. Darren
Post #958503 16th Jul 2022 11:21am
X4SKP
Hello LRA
Point taken... Thumbs Up... 'broadening' the possibilities for those drawn here...
You can complete this direction with E and DOT type approved Smoked LED Headlights...
https://www.originalcaferacer.com/product/...110-black/
Each to their own... probably works best on a dark Defender... Question SKIP
Post #958692 18th Jul 2022 9:22am
