![]() | Home > Technical > Park Brake Light Stuck on, Switch location? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3486 ![]() ![]() ![]() |
I refer to the one arrowed, which I think is the one that illuminates when the brake fluid is low. But I could be wrong, as been a long time since I could use my old 90.
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Soulrider911 Member Since: 04 Jul 2022 Location: California Posts: 108 ![]() ![]() ![]() |
Exactly the impression I was under |
If you loosen the brake reservoir cap and lift the cap just enough that the float is out of the fluid (keeping the cap upright) it should illuminate the brake warning light, whichever that one is
Referring to this schematic, the warning above the low oil pressure warning says ‘spare’. That would be the PARK BRAKE. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1959 ![]() ![]() ![]() |
Oh yes the TD5 or I should say pre puma dash has one! There’s not one on the puma……is there? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Out of curiosity, I took the brake reservoir cap out on the Puma, keeping the cap upright, and there were no new warning lights on the dash. I only had the ignition on, engine not running. Handbrake was off. I do not have ABS.
Checking the electrical manual, it seems like that on the Puma low fluid level should illuminate the handbrake warning light. The handbrake warning illuminates when the handbrake is on. Need to figure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
