Home > Technical > Park Brake Light Stuck on, Switch location?
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey folks. So my park brake is stuck on. I am new to these rad things so still finding my way. Trying to track down where the switch might be, as my assumption is it's a switch/ground issue. I have looked underneath and I do not see a switch... but I could be looking in the wrong area.
I Would love any help. I did find a schematic (that I attached here) looks like the switch should be somewhere under the front cubby?
Also found this, which leads me to believe there is a switch I am just looking in the wrong place
Post #957519 7th Jul 2022 1:15am
landy andy
The switch is attached to the lever / handle mechanism inside the cab, normally inside the rubber boot. It just has one wire going to it which comes through from behind so under the vehicle by the seat box.
Pull the rubber boot off inside and all will be clear Thumbs Up Thumbs Up
Post #957523 7th Jul 2022 3:44am
landy andy
Best pic I can find at this time of day. But should explain.
C0091 is the switch connector
Post #957524 7th Jul 2022 3:49am
Soulrider911
So odd, I actually do not appear to have a switch? Here is a photo of the boot pulled up
Thank you for the help
Post #957525 7th Jul 2022 4:03am
landy andy
Doesn’t look like you do. A better pic
Post #957526 7th Jul 2022 4:10am
Soulrider911
Maybe I have a bulb in the wrong location… maybe the light is actually for something else. Have to take the dash out and maybe look at the wires / colors. I k is there is a schematic out in the wild web somewhere
Post #957527 7th Jul 2022 4:14am
landy andy
Doesn’t even look like you have the mounting holes in your lever assembly.
Post #957528 7th Jul 2022 4:17am
Dinnu
My 1988 90 does not use that Park Brake indicator. The binnacle was also used on Leyland trucks, not just LandRovers, so there are unused warning lights. Could be something done by a previous owner?
As I have commented on your other thread, if the oil level in the brake master is low, it will actually illuminate the warning sign under the battery warning, not the Park Brake.
Edit: Or was it the one on the right of the battery warning... was so long ago 😭 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #957529 7th Jul 2022 4:35am
Soulrider911
Ah ok thank you how do I check the master level? Is it located under the hood? Thank you so much
Post #957531 7th Jul 2022 4:58am
Dinnu
Yes, located under the hood, right above where the brake pedal is located. You might see a sticker / sign to only use Dot3 from a sealed container. You may also use Dot4 as Dot3 is probably hard to find (and is lower specs anyway). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #957533 7th Jul 2022 5:26am
Soulrider911
Thank you for the help, I will take a look tomorrow. I also attached a photo of the bulb harness. Looks like the wire colors are white with a green stripe and black
Post #957535 7th Jul 2022 6:01am
Dinnu
That is a strange wire combination. Land Rover used to use white for supply on the bulb and then a colored (striped or solid) color to the switch that grounds the circuit.
Any idea where the wires go to? Do they go into the main harness? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #957814 10th Jul 2022 12:12pm
bear100
i had a recent leak on one of the metal brake pipes going to the rear, had the same as you with the flickering light at first but then stayed lit, after checking the handbrake switch the reservoir was the next port of call. 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #957821 10th Jul 2022 2:58pm
Soulrider911
Thanks for all the help. I did some searching for wiring schematics, and it’s interesting as they all seem to vary? I decided to go ahead an order a service manual. Figured be good to have if I am going to try and fix these things. According to one schematic I found… green with white strip is signal indicator?
I’ll have to dig In the dash and try to follow the wire
Post #957824 10th Jul 2022 3:50pm
Dinnu
I think the low fluid level in the reservoir illuminates the BRAKE (!) warning light, not the PARK BRAKE. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #957825 10th Jul 2022 4:14pm
