Home > Technical > Park Brake Light Stuck on, Switch location?
Page 2 of 2 <12
bear100
I don’t think there is such a thing as a brake light on the dash? Just a park brake (hand brake)?
When my reservoir was low the hand brake light was the indicator.
The only other brake related light is the ABS as far as I know 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #957826 10th Jul 2022 4:40pm
Dinnu
I refer to the one arrowed, which I think is the one that illuminates when the brake fluid is low. But I could be wrong, as been a long time since I could use my old 90.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #957827 10th Jul 2022 4:57pm
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Dinnu wrote:
bear100 wrote:
i had a recent leak on one of the metal brake pipes going to the rear, had the same as you with the flickering light at first but then stayed lit, after checking the handbrake switch the reservoir was the next port of call.
I think the low fluid level in the reservoir illuminates the BRAKE (!) warning light, not the PARK BRAKE.
Exactly the impression I was under
Post #957833 10th Jul 2022 5:29pm
Dinnu
If you loosen the brake reservoir cap and lift the cap just enough that the float is out of the fluid (keeping the cap upright) it should illuminate the brake warning light, whichever that one is Laughing ignition on, of course. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #957840 10th Jul 2022 6:40pm
Dinnu
Soulrider911 wrote:
Thanks for all the help. I did some searching for wiring schematics, and it’s interesting as they all seem to vary? I decided to go ahead an order a service manual. Figured be good to have if I am going to try and fix these things. According to one schematic I found… green with white strip is signal indicator?
I’ll have to dig In the dash and try to follow the wire
Referring to this schematic, the warning above the low oil pressure warning says ‘spare’. That would be the PARK BRAKE. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #957841 10th Jul 2022 6:55pm
bear100
Oh yes the TD5 or I should say pre puma dash has one! There’s not one on the puma……is there? 2023 Defender L663 V8
Post #957844 10th Jul 2022 7:42pm
Dinnu
Out of curiosity, I took the brake reservoir cap out on the Puma, keeping the cap upright, and there were no new warning lights on the dash. I only had the ignition on, engine not running. Handbrake was off. I do not have ABS.
Checking the electrical manual, it seems like that on the Puma low fluid level should illuminate the handbrake warning light. The handbrake warning illuminates when the handbrake is on. Need to figure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958153 13th Jul 2022 12:55pm
Page 2 of 2 <12
