Home > Puma (Tdci) > Compression Test 0psi
Puma22
I have recently done a compression test, the third cylinder back (I think the order is 1,3,2,4, so cylinder 2?) was reading 0psi.
I will shortly be continuing on with my strip down, however I believe that an inlet valve may be stuck open. There is ‘smoke’ coming from the inlet when cranking for the test. Has anyone come across this before? I can’t find anything online relating to Puma engines and intake valve problems.
Post #957911 11th Jul 2022 2:59pm
hank
Sorry to hear you've got no compression. Explains your crankcase pressure though > 110 XS Double Cab
Post #957915 11th Jul 2022 3:56pm
Puma22
Most certainly. I will continue on and hopeful when I find the cause I can put a post out to help others.
Post #957916 11th Jul 2022 4:00pm
Re: Compression Test 0psi
Puma22 wrote:
I have recently done a compression test, the third cylinder back (I think the order is 1,3,2,4, so cylinder 2?) ...
I think you may be confusing firing order with position. Generally cylinders are numbered 1 to n (where n is the total number) from front to rear, so on a Puma no.2 cylinder is the one between 1 and 3, second from the front. The fact that it is the third cylinder to fire during a full, four stroke cycle, is irrelevant.
Post #957923 11th Jul 2022 5:01pm
landy andy
The third cylinder back is cylinder three. The 1324 is the firing order not the cylinder order.
Post #957995 12th Jul 2022 8:55am
