Home > Maintenance & Modifications > Pre-made Power Cables
X4SKP
Hello All
Some 'Electrickery' advice please...
I am looking to source some Pre-made 'Battery Power Cables' for a 'modification'
I have done this before sourcing...
Car Battery Power Cable / Starting Motor Lead
X1 Pre-made 12'' (305mm) Red Insulation Covered Multi-Copper Strand / 50mm2 / 345 Amp
Cable supplied with Crimped Spade End Terminals / 8mm holes.
X1 (as above) but at 18'' (460mm)
First Question...
Has anyone sourced something similar and can recommend a (potential) good Supplier... Question
(my original source appears to not be trading now...)
Second Question...
Can someone confirm the Specification (Rating Value) of OEM Battery to Starter Cable... Question
With thanks... SKIP
Post #957473 6th Jul 2022 4:31pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
50mm2 is equivalent to 1 AWG (American Wire Gauge)
0/1 - commonly referred to as 'zero gauge' is 55mm2. This is a common size used in (big power) car audio installations.
Your local car audio shop is likely to stock it on a roll and be able to sell to you by the meter, and will also likely stock the terminals you're after.
Back in the (non audio) automtove world, I expect a lot of the usual wiring places stock these types of cable. I'm thinking of companies such as vehicle wiring products and polevolt etc.
Post #957475 6th Jul 2022 4:40pm
X4SKP
Thank you jpboost
It looks like there's routes through Amazon / E-Bay also.
A good on-line source / experience would be good to hear... SKIP
Post #957483 6th Jul 2022 5:28pm
DAZ110
I’ve had power leads made up here in the past:
https://www.mobilecentre.co.uk/
Post #957492 6th Jul 2022 6:41pm
jst
Gywn lewis Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #957502 6th Jul 2022 7:51pm
X4SKP
Thank you All
I would still be interested to know (if someone knows) what the Battery to Starter Motor Lead Specification is... Question
(AMP Rating... specifically) SKIP
Post #957556 7th Jul 2022 8:38am
I can see the appeal of getting something made up and there are companies on eBay that can do so. I'd strongly recommend buying a hydraulic crimping tool and doing it yourself, though. I bought one for around £20 when I built my split charge system and found it very easy to do, with a professional looking finish.
 Darren
Post #957557 7th Jul 2022 8:43am
rallysteve
Happy to make you something up if you wanted?
Think I have all the terminals but would have to get the cable.
Cheers,
Post #957560 7th Jul 2022 9:01am
X4SKP
Gentlemen... Thumbs Up
LRA If this was a regular thing (or even occasional) I need little encouragement Shocked
to buy another tool for the workshop... minimal money really, installing a split charge set up would easily qualify...
What would also add to the 'make-it-up-yourself' argument... is that in my world I would want
every wiring loom / cable 10% longer than supplied, so 'better to work with' / cable management would win out.
I'm fairly sure that what i've done on my 90 with a Security Layer, that has worked faultlessly now
for 8 years and is used every time the engine is switched off, I'm going to repeat on our 'new' 110
So thank you once again for your help and the kind offer rallysteve
I'll source on-line this time. SKIP
Post #957564 7th Jul 2022 9:23am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
jst wrote:
Gywn lewis
This ☝🏻 Roaming around 🇳🇴🇨🇭
Post #957573 7th Jul 2022 11:01am
